Intel® Makers
9881 Discussions
Yocto 3.0 MRAA — Edison GPIO Pins Names Consistency
RVilo
Each environment comes with its number.
Let's take the example for pin D7.
  • Arduino IDE on breakout board = 7
  • Yocto 3.0 MRAA on breakout board = 33
  • Yocto 3.0 MRAA on Arduino board = 7
  • MCU SDK on breakout board = gpio7 = 48
  • MCU SDK on Arduino board = gpio7 = 48
Why the pin number differs for Yocto 3.0 MRAA on breakout board and Arduino board?
I don't remember similar discrepancy for previous Yocto 2.0 MRAA.
Community Manager
Hello rei_vilo,
As you can see in https://github.com/intel-iot-devkit/mraa/blob/master/docs/edison.md https://github.com/intel-iot-devkit/mraa/blob/master/docs/edison.md, it is explain the mraa pin distribution. In the case of the Arduino breakout board, mraa uses the Arduino pin distribution. But for the mini breakout board mraa uses its own pin distribution according to the Module's pins. This has not changed from versions 2.1 to 3.0, even though the document itself has been updated a lot, the table hasn't changed. I suggest you to take a look at the link above.
Peter.
Community Manager
Hello rei_vilo,
Peter.
RVilo
Thank you for the useful link.
