Intel® Makers
9872 Discussions
Yocto 3 seems to have broken SPI even worse than 2
Community Manager
The new update including mraa and Eclipse have changed the way SPI is handled and not all for the better.
If you connect MOSI to MISO for a loop back and do:
const struct sched_param priority={1}; sched_setscheduler(0,SCHED_FIFO,&priority);
mraa_spi_context spi = mraa_spi_init(0);
mraa_spi_mode(spi, MRAA_SPI_MODE0 );
mraa_spi_frequency(spi,10000);
mraa_spi_lsbmode(spi, 0);
mraa_spi_bit_per_word(spi,8);
uint8_t buf[1000];
uint8_t recv[1000];
int i
for(i=0;i<1000;i++)buf[i]=i;
int n=1000;
mraa_result_t res=mraa_spi_transfer_buf (spi, buf, recv,n);
for(i=0;i
if(recv[i]!=buf[i])printf("error %d , %d,%d \n",recv[i],buf[i],i);
mraa_spi_stop(spi);
return MRAA_SUCCESS;
That is send 1000 bytes round the loopback it works for earlier versions of Yocto but it prints errors for after the second byte for the new version.
If you reduce n to 3 then it works i.e. you can send 3 bytes correctly but not more. This seems to happen irrespective of the clock speed.
cchen143
We reproduced this issue.
The root cause is that the frequency you set for SPI is too small10K). Recommend you to set this value more than 1MHz, and the MAX value can be supported to 24MHz
mraa_spi_frequency(spi,10000); --->Change value from 10000 to 1000000, it works
The transfer method in Yocto release 2 is using Polling, and it can not satisfy high performance required.
And now we enabled DMA transferring, the transfer performance can be improved a lot, but it also require to using more higher clock frequency.
Hope it can help you, thanks~
Community Manager
I should have made clear that its the Intel IoT Developer Kit 3.0 and the new firmware that I'm using.
And it the mini expansion board not Arduino board that is in use.
Community Manager
Hi mikejames,
Thank you for reporting this issue. We'll review this and come back with an update as soon as possible.
Diego
Chunguang_C_Intel
Hello James,
Our team works for Edison platform(BSP related). But we are not familiar with MRAA coding, Can you provide completed code, and it will help us to reproduce issue more easier.
Thanks very much!
cchen143
Community Manager
I've tried it at a range of speeds up to 24 Mhz and more - and I get the same wrong behaviour.
What version of the software are you using?
cchen143
I don't know what exact version you have on you side.
Edison source code is fully open sourced, In order to keep the some code base, I suggest you following below steps to pull the latest Edison source code, and have a try with clock frequency 1MHz.
Quick Start
1- Prepare your workspace:
$ mkdir my_Edison_Workspace
2- Get this layer:
$ git clone git://git.yoctoproject.org/meta-intel-edison
3- Make things easier with 'make':
$ ln -s meta-intel-edison/utils/Makefile.mk Makefile
4- Download all the needed dependencies:
$ make setup
5- Build Intel Edison Yocto distribution:
$ make edison-image
6- Flash the board:
$ make flash
cchen143
The test environment we adopted is that:
0. Loopback MOSI to MISO
1. Copy source code below, and save as file "test-spi.c" and then push it to edison board
2. Login Edison by UART or SSH, and then Build code with the command here:
gcc -o test-spi test-spi.c -lmraa
3. Run executable binary
./test-spi
---------------------------------------Source Code------------------------------------
# include
int main()
mraa_spi_frequency(spi,1000000);
uint8_t buf[1000];
uint8_t recv[1000];
int i;
for(i=0;i<1000;i++)
buf[i]=i;
int n=100;
for(i=0;i
if(recv[i]!=buf[i])printf("error Rev: %d , Send: %d, NO: %d \n",recv[i], buf[i], i);
else
printf("----OK---- %d , %d,%d \n",recv[i],buf[i],i);
mraa_spi_stop(spi);
Community Manager
I cant see any difference between your code and the one I'm trying
but I copy and pasted it and it behaves exactly like my code.
I am using the latest OS image that is available and I cant do anything else other than use the publicly available image for the project.
In addition I am restricted to a Windows development system so building the OS isn't easy.
It seems to me that the only possibility is that you are using something ahead of the current release which still leaves everyone installing the official release with a big SPI problem.
You need to realize that unlike Intel engineers most of us simply use and often have to use the official release on the download page.
What this means is that SPI might not be broken in a future version of the OS - but currently it is.
cchen143
The main difference is changing spi frequency from 10KHz you used to 1MHz. Others are the same.
mraa_spi_frequency(spi,10000); 10KHz
mraa_spi_frequency(spi,1000000); 1MHz
Are you downloading the edison release from this link ?
https://software.intel.com/en-us/iot/hardware/edison/downloads IoT - Intel® Edison Board Download | Intel® Developer Zone
In that page, it provided Release 3.0 Yocto complete image.
Intel® Edison Board Firmware Software Release 3.0
https://downloadmirror.intel.com/25871/eng/iot-devkit-prof-dev-image-edison-20160315.zip Release 3.0 Yocto* complete image
http://iotdk.intel.com/repos/3.0/sources http://iotdk.intel.com/repos/3.0/sources
I flashed this image to Edison Arduino board, and checked the release version as below:
root@edison:~# cat /etc/version
201603141535
And then tried it again as the steps I provided to you, and the result is seems good. Please help double check it again, thanks~
./test-spi
Community Manager
I decided that the only way to settle the matter was a complete fresh start.
I downloaded the image and installed it again - although as far as I can tell the image was the same as the one I was already using.
Even so - yes you are correct when the clock speed is 1Mhz or higher the program works.
It fails however if you increase the buffer to 5K but this isn't unreasonable and yes you can most certainly use the Edison SPI bus for real tasks.
For clock rates lower than 1Mhz I have implemented a software emulation and that works well for devices that can't go as fast as 1Mhz - which is the problem I had in the first place.
Thank you for your efforts.
