Intel® Makers
9882 Discussions
Yocto Image build problem
BH1
Hi all,
So I'm building a full yocto image for the Galileo Gen 2, because I want to run Csound on it and use it as a portable synth that accepts MIDI input.
This has been done before, and I'm basing it off this paper: http://lac.linuxaudio.org/2015/papers/2.pdf http://lac.linuxaudio.org/2015/papers/2.pdf
I'm using the BSP and following the build guide. (Available here): https://downloadcenter.intel.com/download/23197/Intel-Quark-BSP?product=79084 Download Intel® Quark™ BSP
So, up until step 6.1, everything is good, but then I get the following error:
ERROR: Layer 'networking-layer' depends on layer 'meta-python', but this layer is not enabled in your configuration
I've checked all my dependencies and I've tried adding "meta-python" folder to the local.conf file but that just throws up another error:
ERROR: Layer 'meta-python' depends on layer 'openembedded-layer', but this layer is not enabled in your configuration
I'm unsure if adding directories to the configuration file is the right approach but I can't take this any further
since there is no "openembedded-layer" directory I can find.
At this point I'm stuck, since without the full yocto install I don't have access to the ALSA libraries needed by CSound.
So if someone could please tell me where I might be going wrong it would be very much appreciated!
Bart
Edit: I'm running Ubuntu 14.04
BH1
Any help with this available?
I've been reading http://www.yoctoproject.org/docs/1.8/bsp-guide/bsp-guide.html# bsp-layers Yocto Project Board Support Package Developer's Guide, but It hasn't given any clues as to how to fix this.
I'm new to the BSP so any advice would be helpful.
PMora5
hello Bart_H,
Did you added the meta-python layer to conf/bblayers.conf? Because all the references for meta directories are listed there.
And in what distro are you building this image?
Paula
Community Manager
Hi Bart_H,
  1. Are you building the default image or are modifying something from the default build?
  2. Have you already tried using https://github.com/openembedded/meta-openembedded meta-openembedded? Remember to add it to the conf/bblayers.conf as Paula mentioned.
  3. Do you know which particular ALSA packages you need? I'm asking this because some of these packages comes with the eglibc image and you might just use this image without the need of building it from scratch. See the packages installed below:
root@galileojdk:~# opkg list-installed | grep alsa
alsa-conf - 1.0.28-r0.0
alsa-conf-base - 1.0.28-r0.0
alsa-lib - 1.0.28-r0.0
alsa-lib-dev - 1.0.28-r0.0
alsa-state - 0.2.0-r5.0
alsa-state-dev - 0.2.0-r5.0
alsa-states - 0.2.0-r5.0
alsa-utils - 1.0.28-r0.0
alsa-utils-aconnect - 1.0.28-r0.0
alsa-utils-alsactl - 1.0.28-r0.0
alsa-utils-alsaloop - 1.0.28-r0.0
alsa-utils-alsamixer - 1.0.28-r0.0
alsa-utils-alsaucm - 1.0.28-r0.0
alsa-utils-amixer - 1.0.28-r0.0
alsa-utils-aplay - 1.0.28-r0.0
alsa-utils-aseqdump - 1.0.28-r0.0
alsa-utils-aseqnet - 1.0.28-r0.0
alsa-utils-dev - 1.0.28-r0.0
alsa-utils-iecset - 1.0.28-r0.0
alsa-utils-midi - 1.0.28-r0.0
alsa-utils-speakertest - 1.0.28-r0.0
Additionally, you can get the eglibc image from the following https://software.intel.com/en-us/iot/hardware/galileo/downloads site
Juan
BH1
Thanks for the response!
PaulaK
Yes, I added the meta-python layer to conf/bblayers.conf. In my original post I mistakenly said I added it to local.conf.
(Both local.conf and bblayers.conf are in the same directory, hence the mix-up)
At that point I get the second error I describe in my original post.
I am using Ubuntu 14.04 LTS
IntelCorporation
1 - For now I am building the default image.
I will want to modify the build after I do a default image trial run and setup the cross-compile toolchain.
2 - I have not tried using meta-openembedded. I was under the impression that it was included in the BSP/updated via the svn?
There are meta-openembedded folders within the BSP and svn repo, but beyond that I'm unsure what I should be doing with meta-openembedded.
3 - I don't know what ALSA packages I will need but I would like to access all of them.
I definitely want an eglibc image for my purposes. However the default eglibc image won't suffice because I want to customise several parts of it.
For example, I would like to modify the libsndfile in meta/recipes-multimedia/libsndfile/libsndfile1.x.x.bb.
Bart
asss
Valued Contributor II
it seems commands like shown below were not executed before ./setup.sh:
$ git config --global user.name "user"
$ git config --global user.email "user@mail.local"
I guess need to delete all files, execute these commands, do a building procedure again.
Another possible solution is to install missed packages like:
sudo apt-get install gcc make patchutils
Last command shall be executed before ./setup.sh
BR,
xbolshe
BH1
I fresh installed Ubuntu 14.04 and included the step recommended by xbolshe:
I'm unfamiliar with git, so I just entered them verbatim as above. I assume "user" doesn't have to be replaced with another username?
The good news is that the meta-python error no longer occurs, however I'm not getting the error shown below:
Does anyone have any advice what the next step might be?
Bart
BH1
It seems that the solutions here maybe have helped:
I ran "sudo apt-get install libsdl1.2-dev" and the full image is now building.
I'll report whether it is successful.
Bart
PMora5
Hi there,
I think this error is thrown in recent Ubuntu versions (14.x and 15.x), I remember I had this issue while trying to bitbake from an Ubuntu machine. I`ve cloned the meta-python layer and tried to bitbake again. I don`t know if this is recommended.
BSP 1.2.1 build guide said it was tested on a Debian wheezy, I think in the future they could include other popular distros as Ubuntu.
Best
Community Manager
Hi
I'm using Ubuntu 14.04 and I'm able to build a default image with the following commands:
cd edison-src
git config --global user.name "myusername"
git config --global user.email "myemail"
mkdir ss dl
./meta-intel-edison/setup.sh --dl_dir=/PathToEdison-Src/edison-src/dl --sstate_dir=/PathToEdison-Src/ss --build_dir=/PathToEdison-Src/edison-src
source poky/oe-init-build-env
bitbake edison-image
Are you using these commands to build the default image with the ww25.5-15 source files? If you are not able to build a image with these commands please let us know and attach the complete error log in a file so we could check and see what we are missing in your image.
Carlos
Community Manager
Hi Bart_H,
Do you have updates on this case? Did you get different results using your own credentials to complete the process?
Pablo
BH1
Hi Pablo,
I was able to finish the build. I have yet to verify if it is successful, but I think it might be (SD LED blinks on boot, it is recognized as a device via USB connection).
I am now trying to figure out how to connect via ssh to the Galileo while running the image I built.
I read that LAN isn't enabled by default on the Galileo? My understanding is that on the default uClibc image, the LAN is enabled via arduino IDE sketch.
Since the arduino IDE normally depends on uClibc, however I'm running an eglibc image, so this won't work (I have tried).
One thing to be aware of - the image files you must save to your SD card don't exactly match the ones listed in the grub.conf file.
For example, the "bzImage.bin" file is by default just called "bzImage" (missing the file extension) in the grub.conf file.
Although it's a trivial edit, without it, the yocto image won't boot on the Galileo.
Regards, Bartley
Community Manager
Hi Bart_H,
With the board connected, do you get any message in the Serial console when you connect the Ethernet cable? You should get a message indicating that a LAN connection has been enabled. Now, for the uClibc image, which is the small/standard image for the Galileo board, the network will be up automatically (you could even use the ping command to test it). For the eglibc image, the larger image for the Galileo, you'll have to bring the network interface up. You'll need to use the ifup and ifdown Linux commands if you want to enable or disable the network interface.
Pablo
BH1
The network connection seems to be up, however I can't SSH to the board.
I'm not going through a router, and then I try to SSH to the board via ethernet and this is what I'm seeing:
I've checked the /etc/ssh/sshd_config file and the port is 22. In short I don't know what I'm doing wrong.
I've been looking up guides but so far no progress. Any advice appreciated.
PMora5
Hi Bart,
Did you connect the Galileo to your local network ? (board and host computer using ssh have to be on the same network through a router....I was never able to ssh when using a direct static connection between my PC and Galileo)
Btw, I saw in the provided image that you ran Arduino sketches on Galileo. I was wondering if you used an sdcard image built under BSP 1.2.1 guide. Because I did not succeed on running arduino ide on a similar image.
Paula
Community Manager
Hi Bart_H,
Did you consider Paula's suggestion? Did you check your configuration? Also, have you checked these instructions on how to connect to a Wi-Fi Network? https://software.intel.com/en-us/node/519955 https://software.intel.com/en-us/node/519955. There are some steps that you might have skipped in your previous attempts.
Pablo
BH1
I connected directly to the ethernet port of my laptop so that's likely the issue with ssh (I haven't tested through my router).
I couldn't get the arduino sketches to work, however I've been using the using the serial monitor in the IDE to connect to the Galileo.
Does anyone know if the default image built by the BSP is uClibc or eglibc?
I can't find eglibc libraries in the image, so I suspect that it's uClibc.
I need to add all of the ALSA libraries also.
I require it to be eglibc. Also, are there any good guides for using yocto and cross compiling programs for it?
Thanks, Bart
FTinetti
Honored Contributor I
Laptop IP and Galileo IP should be in the same LAN segment, range of "visible" IPs.
Fernando.
Community Manager
Hi Bart_H,
Let us know your results once you follow Paula's and FGT's instructions. Regarding your last question about building an eglibc image, you could take a look at this document https://software.intel.com/en-us/blogs/2014/04/04/some-hints-on-yocto-builds-for-iot-devkit-example-... https://software.intel.com/en-us/blogs/2014/04/04/some-hints-on-yocto-builds-for-iot-devkit-example-.... He provides some useful steps and tips that you might want to check.
Pablo
BH1
Hi all,
SSH works fine once I go through my router, thanks for the suggestion Paula
The issue I'm currently working on is getting my Wi-Fi card setup. I'm using an Intel AC 3160 card, which is supported from kernel version 3.10 .
Since my yocto image is kernel 3.14 it should work (with the correct firmware).
I've been following this guide (which is recommended on this forum several times!) http://www.malinov.com/Home/sergey-s-blog/intelgalileo-addingwifi Intel Galileo Meets Wireless - Malinov Family Web Presence
I've followed the steps, although the wifi card isn't showing up when I run the "ifconfig" and "ifup wlan0" commands and I've no idea why.
I've extracted and copied the correct firmware from https://wireless.wiki.kernel.org/en/users/Drivers/iwlwifi https://wireless.wiki.kernel.org/en/users/Drivers/iwlwifi to the /lib/firmware directory.
Since the card isn't recognized I can't progress any further.
Regards, Bart
PMora5
Hi Bart,
I'm glad that you were able to use SSH.
About your wifi card... Could you post the result of this two commands please?
ifconfig -a
To check if your wifi-card was recognized correctly.
modinfo iwlwifi | grep iwlwifi
To show all the drivers regarding wifi cards installed on your OS.
Best.
