Intel® Makers
9882 Discussions
Yocto Project bitbake kernel ACPI/HPET build error
GGan5
Hi guys, I'm currently attempting to build a custom Linux Kernel using bitbake with ACPI and HPET features, but encountered some build error during the attempt. The sources are edison-src-ww25.5-15.tgz, which is from release 2.1. Strangely enough, the build pass when building a vanilla kernel without these features enabled.
If I'm not mistaken HPET requires ACPI to be enabled in order to expose it on the Linux OS. When ACPI is disabled the HPET options under Character Devices is simply missing too.
Following is the build error log upon executing bitbake -f virtual/kernel:
Any insights would be helpful since I'm going to need HPET instead of TS as the clock source for getting data out of SPI periodically. Unfortunately SPI feature is still not supported in the MCU as of release 2.1.
UPDATE:
I've tried to enable ACPI and HPET using the build from release 1.6. Following are the screenshots of the kernel config. Building is sucessful without the following changes:
Bitbake build error log:
| static void __init wifi_platform_data_init_sfi_gpio(void)
| CC crypto/api.o
| LD arch/x86/platform/intel-mid/device_libs/built-in.o
| CC arch/x86/platform/intel-mid/mfld.o
| CC kernel/futex.o
| /home/gary/Development/edison-build/edison-src/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17+gitAUTOINC+6ad20f049a_c03195ed6e-r0/linux/arch/x86/platform/intel-mid/mfld.c:86:7: warning: function declaration isn't a prototype [-Wstrict-prototypes]
| void *get_penwell_ops()
| /home/gary/Development/edison-build/edison-src/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17+gitAUTOINC+6ad20f049a_c03195ed6e-r0/linux/arch/x86/platform/intel-mid/mfld.c:91:7: warning: function declaration isn't a prototype [-Wstrict-prototypes]
| void *get_cloverview_ops()
| CC arch/x86/platform/intel-mid/mrfl.o
| CC crypto/cipher.o
| /home/gary/Development/edison-build/edison-src/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17+gitAUTOINC+6ad20f049a_c03195ed6e-r0/linux/arch/x86/platform/intel-mid/mrfl.c:152:7: warning: function declaration isn't a prototype [-Wstrict-prototypes]
| void *get_tangier_ops()
| /home/gary/Development/edison-build/edison-src/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17+gitAUTOINC+6ad20f049a_c03195ed6e-r0/linux/arch/x86/platform/intel-mid/mrfl.c:158:7: warning: function declaration isn't a prototype [-Wstrict-prototypes]
| void *get_anniedale_ops()
| CC arch/x86/platform/intel-mid/intel_mid_pcihelpers.o
| CC crypto/compress.o
| CC arch/x86/platform/intel-mid/intel_mid_scu.o
| CC kernel/rtmutex.o
| CC crypto/algapi.o
| CC arch/x86/platform/intel-mid/board.o
| In file included from /home/gary/Development/edison-build/edison-src/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17+gitAUTOINC+6ad20f049a_c03195ed6e-r0/linux/arch/x86/platform/intel-mid/board.c:82:0:
| /home/gary/Development/edison-build/edison-src/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17+gitAUTOINC+6ad20f049a_c03195ed6e-r0/linux/arch/x86/platform/intel-mid/device_libs/platform_spidev.h:17:0: warning: "FORCE_CHIP_SELECT" redefined [enabled by default]
| # define FORCE_CHIP_SELECT 1
| In file included from /home/gary/Development/edison-build/edison-src/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17+gitAUTOINC+6ad20f049a_c03195ed6e-r0/linux/arch/x86/platform/intel-mid/board.c:81:0:
| /home/gary/Development/edison-build/edison-src/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17+gitAUTOINC+6ad20f049a_c03195ed6e-r0/linux/arch/x86/platform/intel-mid/device_libs/platform_max3111.h:17:0: note: this is the location of the previous definition
| # define FORCE_CHIP_SELECT 0
| In file included from /home/gary/Development/edison-build/edison-src/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17+gitAUTOINC+6ad20f049a_c03195ed6e-r0/linux/arch/x86/platform/intel-mid/board.c:83:0:
| /home/gary/Development/edison-build/edison-src/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17+gitAUTOINC+6ad20f049a_c03195ed6e-r0/linux/arch/x86/platform/intel-mid/device_libs/platform_ads7955.h:17:0: warning: "FORCE_CHIP_SELECT" redefined [enabled by default]
| /home/gary/Development/edison-build/edison-src/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17+gitAUTOINC+6ad20f049a_c03195ed6e-r0/linux/arch/x86/platform/intel-mid/device_libs/platform_spidev.h:17:0: note: this is the location of the previous definition
| CC arch/x86/platform/intel-mid/intel_soc_pmu.o
| CC kernel/rt.o
| /home/gary/Development/edison-build/edison-src/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17+gitAUTOINC+6ad20f049a_c03195ed6e-r0/linux/arch/x86/platform/intel-mid/intel_soc_pmu.c: In function 'set_enable_s0ix':
| /home/gary/Development/edison-build/edison-src/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17+gitAUTOINC+6ad20f049a_c03195ed6e-r0/linux/arch/x86/platform/intel-mid/intel_soc_pmu.c:881:15: error: 'struct mid_pmu_dev' has no member named 'cstate_ignore'
| mid_pmu_cxt->cstate_ignore =
| /home/gary/Development/edison-build/edison-src/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17+gitAUTOINC+6ad20f049a_c03195ed6e-r0/linux/arch/x86/platform/intel-mid/intel_soc_pmu.c:885:15: error: 'struct mid_pmu_dev' has no member named 'cstate_ignore'
| mid_pmu_cxt->cstate_ignore |= (1 << 1);
| /home/gary/Development/edison-build/edison-src/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17+gitAUTOINC+6ad20f049a_c03195ed6e-r0/linux/arch/x86/platform/intel-mid/intel_soc_pmu.c:886:15: error: 'struct mid_pmu_dev' has no member named 'cstate_ignore'
| mid_pmu_cxt->cstate_ignore |= (1 << 2);
| /home/gary/Development/edison-build/edison-src/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17+gitAUTOINC+6ad20f049a_c03195ed6e-r0/linux/arch/x86/platform/intel-mid/intel_soc_pmu.c:887:15: error: 'struct mid_pmu_dev' has no member named 'cstate_ignore'
| mid_pmu_cxt->cstate_ignore |= (1 << 4);
| /home/gary/Development/edison-build/edison-src/build/tmp/work/edison-poky-linux/linux-yocto/3.10.17+gitAUTOINC+6ad20f049a_c03195ed6e-r0/linux/arch/x86/platform/intel-mid/intel_soc_pmu.c:890:15: error: 'struct mid_pmu_dev' has no member named 'cstate_ignore'
| mid_pmu_cxt->cstate_ignore |= (1 << 6);
| /home...
Pablo_M_Intel
Hi D.Sync,
Could you please explain in detail which process are you following to build the custom kernel with ACPI and HPET? Did you already check the dependencies for both ACPI and HPET? Make sure to enable these dependencies (in case there are any) as they might be causing the issue.
Pablo
Pablo_M_Intel
Hi D.Sync,
So according to your update on your original post, you were able to build the image with ACPI and HPET enabled, right? Have you tried using a more recent image? Not necessarily the 2.1 dev-kit image, because this one seems to lack the member that you mentioned above. We will pass this information to the development team, I believe this should be addressed in future images.
Pablo
GGan5
Hi Pablo,
Yes I've managed to build the settings using release 1.6. One thing to note is the /dev/hpet is still not exposed and shown even though the kernel is successfully. I've yet to try it out on Release 2.1 and will send some updates if I managed to make any progress on that.
Pablo_M_Intel
Hi D.Sync,
Please keep us posted in case you try it with a newer image.
Pablo
