Intel® Makers
Intel® Edison, Intel® Joule™, Intel® Curie™, Intel® Galileo
Welcome - This is a Peer-to-Peer Forum only. Intel has discontinued these products but you may find support from other customers on this Forum
9869 Discussions
Yocto on Galileo Compiling problem
Lei_Z_Intel
Hi Sir/Ma'am,
I am following the instruction of
https://webmail.intel.com/owa/redir.aspx?C=a0gCsWlBMkq0SevW3xokHenZKuw8NNEI8ebp6Sg3MbmhY9K7OfTVNJdSs... http://www.malinov.com/Home/sergey-s-blog/intelgalileo-buildinglinuximage
and Intel® Quark SoC X1000 Board Support Package (BSP) Build Guide
to build the system.
When I run: bitbake core-image-minimal
the result is good.
When I run: bitbake image-full
the result is:
| ERROR: Function failed: do_compile (see /home/leizhou/Workspace/Galileo/meta-clanton_v0.7.5/yocto_build/tmp/work/x86_64-linux/guile-native/2.0.7-r1/temp/log.do_compile.16399 for further information)
ERROR: Task 2016 (virtual:native:/home/leizhou/Workspace/Galileo/meta-clanton_v0.7.5/poky/meta/recipes-devtools/guile/guile_2.0.7.bb, do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2727 tasks of which 2701 didn't need to be rerun and 1 failed.
I am using Fedora 19.
Could you give me some suggestions for this?
Lei
AT9
Out of the error message it looks like you're trying to build these two images in the same Yocto working dir. Minimal and full images are different enough to be incompatible.
Either delete all but "conf" directory inside the "yocto_build" one (simpler and more robust method) or run "bitbake -c cleansstate core-image-minimal" before building the full one to cleanup properly.
If neither of the above works, post the contents of the log file mentioned in the error message.
Lei_Z_Intel
Hi ALex,
Thanks for the quick response.
I run as you mentioned, the result is the same. I appended the log file. Could you please help check it?
I really appreciate your help.
Lei
AT9
Thanks. ok, it's still enigmatic enough in the log as well. But after re-reading your initial post, I see you're using fedora 19. It's old enough, probably, but I haven't tried it personally and I've seen things breaking during the Yocto builds due to specific make or gcc or other tool or lib versions.
Is trying ubuntu 12.04 or openSUSE 12.3 (two versions I personally verified to work + there were reports from others) is an option for you? That may be the fastest way to a resolution. You can e.g. try my VM image based on openSUSE I've announced in this community earlier.
Lei_Z_Intel
Hi Alex,
Thanks for your response.
I found a link for guile recipe: fix the depends for target recipes
http://git.yoctoproject.org/cgit/cgit.cgi/poky/commit/?h=dylan&id=59e8d60e250d8dea3fd2fc48f42cf17cad... poky - Poky Build Tool and Metadata
And I made change base on it. At least, the building finished without error. Is it the right way?
Thanks again.
Lei
AT9
If it fixes it for you - it definitely is :-) That's pretty much the way I used a couple of times already to fix glitches with dmidecode and elfutils compilations, which are incorporated into my Yocto layer at github.com.
Thanks for reporting back - now we have a problem revealed and a fix found for building Galileo BSP on Fedora 19, which is very nice - good job.
