Intel® Makers
9882 Discussions
Zephyr SDK Download Error
TOyam3
Hi all,
I am trying to re-install the M tree using Intel's directions at https://software.intel.com/en-us/node/675543 Installing and Using the M Tree | Intel® Software
I have Ubuntu 16.04. I have previously downloaded all the trees and zephyr in June.
When I get to the make setup step and the Zephyr 0.9.1 SDK begins to dowload, I get the error:
Setting up x86 Firmware
Downloading Zephyr
Installing Zephyr to /home/tamrako/CODK2/zephyr
Downloading Zephyr SDK
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 178 100 178 0 0 175 0 0:00:01 0:00:01 --:--:-- 175
100 40418 0 40418 0 0 17159 0 --:--:-- 0:00:02 --:--:-- 35641
Installing Zephyr SDK to /home/tamrako/CODK2/zephyr-sdk
/tmp/zephyr-sdk-0.9.1-i686-setup.run: line 1: syntax error near unexpected token `newline'
/tmp/zephyr-sdk-0.9.1-i686-setup.run: line 1: `<!DOCTYPE html>'
Makefile:108: recipe for target 'x86-setup' failed
make: *** [x86-setup] Error 2
Does anyone know what's going on?
Community Manager
Hi tamrako,
Thanks for your patience.
A link seems to be broken, please apply the patch (zephyr_sdk.patch) provided to have a successful install.
mkdir -p ~/CODK && cd $_
git clone https://github.com/01org/CODK-M.git https://github.com/01org/CODK-M.git
cd CODK-M
make clone
**Need to copy patch to this dirrectory**
patch -p0 < zephyr_sdk.patch
sudo make install-dep
make setup
export CODK_DIR=$(pwd)
source ../zephyr/http://zephyr-env.sh/ zephyr-env.sh
Hope this information helps.
-Yermi A.
Community Manager
Hi tamrako,
Thanks for reaching out.
I have tried to install the M-Tree and I've gotten the same error message, I would like to investigate a little bit regarding this issue and as soon as I have updates I'll let you know.
I'll appreciate your patience during the meantime.
-Yermi A.
Community Manager
Hi tamrako,
cd CODK-M
make clone
make setup
-Yermi A.
JZhou28
Hi Yermi,
I've been working with Tamra on the same project. I recently downloaded the SDK with the patch. The download is success but it seems to miss a directory i586-zephyr-elf. Tamra used the patch about a week ago and her environment is fine, so I'm wondering if there is another change made that results in the error. The lack of i586-zephyr-elf directory results me not being able to compile (with make command) any application Whenever I try to compile it throws this error:
/home/vanissy/CODK/zephyr-sdk/sysroots/x86_64-pokysdk-linux/usr/bin/i586-zephyr-elf/i586-zephyr-elf-gcc: not found
Jie
Community Manager
Hi Jie,
We are not able to duplicate the error that you are reporting. We followed the steps on applying the patch, as well as the guide available in this site: https://software.intel.com/en-us/node/675543
Could you please tell us what steps you followed or which guide you are using?
Diego V.
Community Manager
Hi Jie,
Do you still need assistance in this case? If so, Could you please tell us what steps you followed or which guide you are using?
-Yermi A.
JZhou28
Hi Yermi,
Yeah I tried the same instruction steps on another linux computer, and it works fine. So, it is something with my own machine, I'll fix it since I know where the issue is now. Thank you very much for your help.
Sincerely,
Jie
