Community
cancel
Showing results for
Search instead for
Did you mean:
NHerm1
a bootable device has not been detected
Hallo Intel community
I'm really happy with my Intel compute stick but yesterday when booting it it displays the following message: a bootable device has not been detected
When I try to select a device to boot from no drive is available for selection unless I plug in a USB stick, installing a new OS also doesn't detect a drive.
in normal circumstances I'd replace the drive but this doesn't seem possible with the compute stick.
Has anyone had a problem like this before, I can't seem to find any info online.
Thanks in advance for any help / feedback provided.
NHerm1
I've been trying to get it to work again but all attempts have failed so far. Is really no one dealing with this issue?
Cesar_B_Intel
Hello Nick_Hermans,
Are you getting any error codes?
Have you tried a hard reset?
I suggest accessing the recovery media (If using Windows version):
1- If Windows boots, from Windows Start, type in Recovery and select Recovery Options. See
http://windows.microsoft.com/en-us/windows-8/restore-refresh-reset-pc http://windows.microsoft.com/en-us/windows-8/restore-refresh-reset-pc for complete details on how
to use the recovery options.
2- If Windows fails to boot, the recovery process should automatically start.
3- If Recovery does not automatically start, you can try to initiate it as follows:
-. Press F8 during boot (when you see the prompt "F8 to Activate Windows 8.1 Recovery
Mode").
2. Follow the recovery steps.
You may get more information here http://download.intel.com/support/motherboards/desktop/stck1a32wfc/sb/stck1a32wfc_eng_userguide01.pd... http://download.intel.com/support/motherboards/desktop/stck1a32wfc/sb/stck1a32wfc_eng_userguide01.pd...
Please post your results here.
Caesar B.
