Intel® Makers
9882 Discussions
about TinyB -DBUILDJAVA=ON option
mkim29
i try install following this post. i want to excute java and gave option. cmake -DBUILDJAVA=ON.
but i got this error. just follow step.. T_T.
what is problem? and question is how can i use TinyB lib in java?
plz answer me
Community Manager
Are you using the latest image and were able to follow all the steps from /message/379236# 379236 https://communities.intel.com/message/379236# 379236 successfully?
If you have, post the contents of CMakeOutput.log and of CMakeError.log.
Sergio
mkim29
yes. i follow all setps that post.
this is CMakeError.log
Community Manager
By just looking at that log it's difficult to find the specific error. One interesting line is the "Could not find Java" message. Did you make any previous Java installation or modification? Did you change any paths? I'd recommend to run the command make doc according to https://github.com/intel-iot-devkit/tinyb https://github.com/intel-iot-devkit/tinyb to see if you can find useful information in the documentation.
Also, please also provide the output of CMakeOutput.log
Sergio
Community Manager
Have you found our previous suggestion helpful? Were you able to use tinyB?
Sergio
