Intel® Makers
9881 Discussions
access to the web page (edison bord) was denied
Community Manager
hello
I have a problem with edison for arduino.
The web page ( http://***.***.*.** my edison bord's address) refused access.
I tried to access it by wifi.
My computer and edison device are joined same wifi .
Community Manager
Hello Masahiro,
Thank you for your patience.
The reason it's refusing connection could be that port 80 is occupied. The avoid this issue use any other port instead of 80. Update line in code in the sketch WiFiServer server(80); with WiFiServer server(81);.
After running the sketch, url address also could be updated with the port number for web browser. For example if your IP address is 123.234.23.12 - add the :81 at the end: http://123.234.23.12:81.
Or you can follow the steps in this thread. It seems they had the same issue as you and were able to fix it: https://communities.intel.com/message/275569# 275569 https://communities.intel.com/message/275569# 275569
Hope this helps.
Octavian
Community Manager
Hello Masahiro,
Thank you for your interest in our Intel products.
Can you please elaborate on the steps you were doing trying to connect to your board? Are you trying to configure Edison as a webserver? What is the error message you're getting?
Octavian
Community Manager
I'm sorry that the information was not enough.
I just try to set up Wifi of the edison.
I used PuTTY and finished all operations on PuTTY.
Then I tried to connect it as check.
Community Manager
Hello Masahiro,
Have you followed the steps in this guide? https://software.intel.com/en-us/connecting-your-intel-edison-board-using-wifi
Let me know if the guide helps fix your issue or we can investigate the issue further.
Octavian
Community Manager
Yes, I did.
The edison board is connected wifi, but it refuses.
Community Manager
Hello Masahiro,
Hope this helps.
Octavian
