after upgrade to window 10 system stops working after @30 seconds you can boot in safe mode and go to settings and verify the windows 10 version but when you restart system it will freeze up again? what can be done in safe mode? Also sometimes in Post it will come up with error 0xc0000225 ?
Hello Ronnie_530,
Thank you for joining the Intel communities.
Was the unit purchased with Windows 8.1 or pre-installed Windows 10?
Please try the following:
Update the Intel® Compute Stick BIOS; please download the latest BIOS version for this unit from the following link:
https://downloadcenter.intel.com/download/25506/BIOS-Update-FCBYT10H-86A- Download BIOS Update [FCBYT10H.86A]
In this case I recommend doing a BIOS recovery and you can follow the steps here:
http://www.intel.com/support/motherboards/desktop/sb/CS-035445.htm Intel® Compute Stick — BIOS Recovery Instructions
After that is done reset the system to factory defaults:
- Remove any SD card, if installed.
- Press F8 when you see this prompt during boot: F8 to Activate Windows 8.1* Recovery Mode.
- Select Troubleshoot.
- Select Reset your PC, then select Next.
- Select just remove my files.
- Select Reset to start the restore process.
If this troubleshooting work for you, try upgrading to Windows 10 again, but before doing so, update Windows through Windows update with all the updates available and follow the steps to upgrade to Windows 10 at:
http://www.intel.com/support/motherboards/desktop/stck1a32wfc/sb/CS-035724.htm Intel® Compute Stick STCK1A32WFC — Windows® 10 Upgrade Instructions
Please let me know if that works for you.
Regards!
Ivan
Samething happened to me after updating to windows 10. It was a nuisance I was able to resolve it last night with a bios update. You'll need a separate computer to do this.
Good Luck.
Esta pregunta es una supuesta respuesta.
Marco Montenegro 17-dic-2015 15:56
Despues de varios intentos fallidos para actualizar mi pc stick de win 8.1 a win 10 , y consultando foros como hacerlo , lo actualice , se demoro mas de 12 horas pero seguia congelandose , se pegaba , al final tanto reiniciarlo no partio mas llegaba hasta restaurar el sistema y ahi se quedaba , y volvia a reiniciarse sin encontrar ninguna solucion y pensarlo en llevarlo al servicio tecnico de
Intel aca en Chile.
Pero se me ocurrio algo y solucione todo , ojala esto sirva para todos los que tienen este problema de actualizacion a win 10 .
1 baje la iso original de win 10 de la pagina de microsoft
2 baje el programa rufus desde su pagina
3 con un pendrive de 4 gigas , la iso de win 10 y rufus , cree una usb boteable con particion gtp uefi y el pendrive lo formatie ntfs , esto lo hace todo rufus tu solo cambia los parametros que yo ocupe.
4 puse un hub usb 2.0 y conecte al puerto usb del pc stick agregue el teclado y el mouse mas el pendrive
5 arranque el pc stick y con F10 lo botie del pendrive espere unos minutos y empezo la instalacion de win 10 , no formatie el disco duro , lo instale en la misma particion en que estaba instalado la vercion anterior y esta paso a hacer windows.old , tampoco puse la serial omiti este paso y se intalo como en 30 minutos .
6 despues baje los drivers de la pagina de intel , los instale y tambien me di cuenta que windows 10 quedo activado automaticamente sin ingresar serial
espero que este mini tutorial sirva a esas personas que tenian mi problema
Thanks you tuto for that information that you kindly provided, I'm sure this information can help others with this issue.
Thanks and regards!
Ivan
