Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
New Contributor II
alsa raw data issue
Hi All,
I have two .wav sound files.
When I do "aplay "
One of them is played properly. But the other one is giving a disturbing sound.
The difference in output of both the files is :
Playing WAVE 'bubble.wav' : Signed 16 bit Little Endian, Rate 44100 Hz, Stereo
Playing raw data 'Hello.wav' : Unsigned 8 bit, Rate 8000 Hz, Mono
Does anyone have an idea on this? What exactly playing raw data mean?
--Paridhi
Highlighted
IMHO *.wav is not raw data.
you'd have to give more log data in order to analyze your prob.
e.g. "aplay -vv" or "aplay -vvv" should already give some more info.
Besides which of those files plays "correctly"?
is it correct that one is stereo 16 bit, 44.1kHz and the other only 8bit mono 8kHz?
Highlighted
New Contributor II
Hi mhahn,
Following is the output for file not working:
root@quark003356:~# aplay -vvv Hello.wav
Plug PCM: Rate conversion PCM (48000, sformat=U8)
Converter: linear-interpolation
Protocol version: 10002
Its setup is:
stream : PLAYBACK
access : RW_INTERLEAVED
format : U8
subformat : STD
channels : 1
rate : 8000
exact rate : 8000 (8000/1)
msbits : 8
buffer_size : 4000
period_size : 1000
period_time : 125000
tstamp_mode : NONE
period_step : 1
avail_min : 1000
period_event : 0
start_threshold : 4000
stop_threshold : 4000
silence_threshold: 0
silence_size : 0
boundary : 262144000
Slave: Route conversion PCM (sformat=S16_LE)
Transformation table:
0 <- 0</em>
1 <- 0</em>
Its setup is:
stream : PLAYBACK
access : MMAP_INTERLEAVED
format : U8
subformat : STD
channels : 1
rate : 48000
exact rate : 48000 (48000/1)
msbits : 8
buffer_size : 24006
period_size : 6000
tstamp_mode : NONE
period_step : 1
avail_min : 6000
period_event : 0
start_threshold : 24000
stop_threshold : 24006
silence_size : 0
boundary : 1573257216
Slave: Hardware PCM card 0 'C-Media USB Headphone Set' device 0 subdevice 0
Its setup is:
stream : PLAYBACK
format : S16_LE
subformat : STD
channels : 2
rate : 48000
msbits : 16
buffer_size : 24006
period_size : 6000
tstamp_mode : NONE
period_step : 1
avail_min : 6000
period_event : 0
silence_size : 0
appl_ptr : 0
hw_ptr : 0
100%
100%
100%
100%
100%
100%
Max peak (1000 samples): 0x00000080 # Max peak (1000 samples): 0x00000080 # Max peak (1000 samples): 0x00000080 # Max peak (1000 samples): 0x00000080 # Max peak (1000 samples): 0x00000080 # Max peak (1000 samples): 0x00000080 # root@quark003356:~#
--Paridhi
Highlighted
New Contributor II
hi mhahn,
This is the output of file "fresh.wav" which is working: (Is there a way I can attach my audio files in this discussion?)
root@quark003356:~# aplay -vvv fresh.wav
Playing WAVE 'fresh.wav' : Unsigned 8 bit, Rate 11025 Hz, Mono
Plug PCM: Rate conversion PCM (44100, sformat=U8)
Its setup is:
stream : PLAYBACK
format : U8
subformat : STD
channels : 1
rate : 11025
exact rate : 11025 (11025/1)
msbits : 8
buffer_size : 5513
period_size : 1378
period_time : 125011
tstamp_mode : NONE
period_step : 1
avail_min : 1378
period_event : 0
start_threshold : 5513
stop_threshold : 5513
silence_size : 0
boundary : 361299968
0 <- 0</em>
1 <- 0</em>
Its setup is:
stream : PLAYBACK
format : U8
subformat : STD
channels : 1
rate : 44100
exact rate : 44100 (44100/1)
msbits : 8
buffer_size : 22056
period_size : 5513
tstamp_mode : NONE
period_step : 1
avail_min : 5513
period_event : 0
start_threshold : 22052
stop_threshold : 22056
silence_size : 0
boundary : 1445462016
Its setup is:
stream : PLAYBACK
format : S16_LE
subformat : STD
channels : 2
rate : 44100
msbits : 16
buffer_size : 22056
period_size : 5513
tstamp_mode : NONE
period_step : 1
avail_min : 5513
period_event : 0
silence_size : 0
appl_ptr : 0
hw_ptr : 0
21%
61%
56%
21%
84%
26%
19%
36%
72%
10%
6%
33%
22%
7%
14%
33%
39%
72%
63%
52%
45%
66%
54%
28%
26%
100%
53%
42%
47%
19%
57%
48%
10%
27%
67%
68%
38%
36%
43%
61%
25%
25%
10%
7%
21%
7%
20%
24%
23%
43%
28%
26%
7%
16%
28%
21%
15%
33%
23%
73%
71%
29%
24%
25%
17%
59%
14%
71%
7%
17%
50%
7%
3%
Max peak (1378 samples): 0x0000001c # Max peak (1378 samples): 0x0000004f # Max peak (1378 samples): 0x00000048 # Max peak (1378 samples): 0x0000001c # Max peak (1378 samples): 0x0000006c # Max peak (1378 samples): 0x00000022 # Max peak (1378 samples): 0x00000019 # Max peak (1378 samples): 0x0000002f # Max peak (1378 samples): 0x0000005d # Max peak (1378 samples): 0x0000000e # Max peak (1378 samples): 0x00000008 # Max peak (1378 samples): 0x0000002b # Max peak (1378 samples): 0x0000001d # Max peak (1378 samples): 0x0000000a # Max peak (1378 samples): 0x00000012 # ...
Highlighted
New Contributor II
HI mhahn,
Does it also have to do with the kind of formats my sound card supports irrespective of what aplay can? It was not working on Galileo , so I tried running the same on Ubuntu 12.04. Same issue occurs there.
--Paridhi
Highlighted
sure - just tried to analyze from the very beginning 😉
you could e.g. convert the data format using gstreamer to make it fitting to your sound card
Highlighted
New Contributor II
Hi mhahn
Searching about it on internet led me to one of the RasberryPi's forum http://www.raspberrypi.org/forums/viewtopic.php?f=38&t=20866&start=25 Raspberry Pi • View topic - USB soundcard...Finally good (non HDMI) Analog Audio ,wherein it says that "Alsa can sometimes be a pain, the recording rate 8000Hz you chose for arecord is probably not supported by the card."
Do you know how can I get sampling rate of 8000Hz to work with alsa ? Or do you suggest an alternative to alsa for Galileo?
--Paridhi
Highlighted
as mentioned: you might use gstreamer to resample to a fitting rate
Highlighted
New Contributor II
hi mhahn,
Can you point me to the gstreamer repo for galileo?
I am able to find for edison which is not compatible it says.
Highlighted
not sure which Galileo image you use. If it's the eglibc one from Intel(R) IoT devkit, then you can take from http://iotdk.intel.com/repos/1.1/iotdk/i586/ i586/ (gst-*). If you're on a uclibc image AlexT_Intel might be able to add to his repo if you kindly ask him
Highlighted
Adding gstreamer is definitely a possibility though I suspect that if it doesn't play on the Ubuntu system, then it's neither Galileo nor ALSA is the reason, but the file is simply corrupted (or the sound that was recorded was of the kind you hear back?).
Paridhi_Agrawal, you can attach files to your posts, just click on the "Use advanced editor" link in the upper right-hand corned of the post editor and then there will be a link for attaching files in the lower right-hand corned, next to "Mention" and "App". Attach your file, I'd be curious to look at it.
Highlighted
AlexT_Intel only some wav files play. gstreamer would be used to resample to a format the soundcard would support
Highlighted
Yeah, that might be a card limitation too, I just took the "tried on Ubuntu" as if it was a different card there. Paridhi_Agrawal, do you mean that you've moved the USB sound card + the wav file in question to the Ubuntu machine, then trying to play it back through the same card and it didn't work? Or that Ubuntu machine had a different sound card?
Highlighted
New Contributor II
Hello All,
I have found a workaround solution to my problem
Here is what I did:
Since , the .wav raw U8 8 bit 8000Hz Mono format of my file was not playing using aplay on Gen1 (it was giving noise) , I found .mp3 version for same and
did the following to play it through aplay:
1) Downloaded http://sourceforge.net/projects/lame/files/lame/3.99/lame-3.99.5.tar.gz http://sourceforge.net/projects/lame/files/lame/3.99/lame-3.99.5.tar.gz
untar
./configure
make
make install
2) on the shell: lame --decode gw.mp3 gw_con.wav
3) aplay gw_con.wav and it works !!
--Paridhi
