Intel® Makers
Intel® Edison, Intel® Joule™, Intel® Curie™, Intel® Galileo
Welcome - This is a Peer-to-Peer Forum only. Intel has discontinued these products but you may find support from other customers on this Forum
9867 Discussions
auto connect to the wifi using intel edison
OSh
Hi Guys, I would like to check whether intel Edison is it possible for the intel Edison to automatically connect to the wifi when it is power on. I am currently using SparkFun Arduino Block and Base Block together with intel Edison
Community Manager
Hi chaos39,
This feature is available in the latest image and some of the previous ones as well. In my case, I'm using the latest one, where cat /etc/version outputs 201606061707 and the Arduino expansion board. Once I connect to a network, every time I use the Edison, the connection to that same network remains. You can download the latest image here https://software.intel.com/en-us/iot/hardware/edison/downloads https://software.intel.com/en-us/iot/hardware/edison/downloads .
Let us know if this works for you.
-Sergio
OSh
Hi Mr. Sergio, I do like to apologize for the late reply. I was wondering if there is any website link that I can refer to, it will help me to understand better
Community Manager
To flash the latest image to your board you can use the Flash Tool Lite. There are instructions on how to download and install the flash tool lite here https://software.intel.com/en-us/articles/flash-tool-lite-user-manual https://software.intel.com/en-us/articles/flash-tool-lite-user-manual . Follow these steps to flash the latest image to your board. The latest image can be found here https://software.intel.com/en-us/iot/hardware/edison/downloads https://software.intel.com/en-us/iot/hardware/edison/downloads .
Let us know if you're able to auto connect to WiFi after having flashed the latest image.
-Sergio
Community Manager
Do you still need assistance with this thread, were you able to flash the board?
-Sergio
OSh
thanks for the reply, it helps a lot
Community Manager
Thank you for letting us know our previous suggestion worked. If you have any other questions don't hesitate to open a new thread to get help from the community.
-Sergio
