Community
cancel
Showing results for
Search instead for
Did you mean:
AOrlo6
bitbake does not see contextlib module
I am trying to bitbake Edison image from 'edison-src-ww18-15.tgz' tarball as it described in http://www.intel.com/content/dam/support/us/en/documents/edison/sb/edisonbsp_ug_331188007.pdf BSP User Guide. But process stops with error message: 'ImportError: No module named contextlib':
artem@ubuntu:~/SDK/edison-src$ bitbake edison-image
Traceback (most recent call last):
File "/home/artem/SDK/edison-src/poky/bitbake/bin/bitbake", line 34, in
import bb
File "/home/artem/SDK/edison-src/poky/bitbake/lib/bb/__init__.py", line 75, in
import bb.msg
File "/home/artem/SDK/edison-src/poky/bitbake/lib/bb/msg.py", line 32, in
import bb.event
File "/home/artem/SDK/edison-src/poky/bitbake/lib/bb/event.py", line 34, in
import bb.utils
File "/home/artem/SDK/edison-src/poky/bitbake/lib/bb/utils.py", line 35, in
from contextlib import contextmanager
I already have this module in my system (Ubuntu 14.04 LTS):
artem@ubuntu:~/SDK/edison-src$ python --version
Python 2.7.3
artem@ubuntu:~/SDK/edison-src$ ls -la /usr/lib/python2.7 | grep contextlib
-rw-r--r-- 1 root root 4424 Jun 22 2015 contextlib.py
But when I try to import it manually python fails:
Python 2.7.3 (default, Jun 19 2015, 12:59:29)
[GCC 4.9.1] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import contextlib
File "", line 1, in
Please help me import contextlib to my python!
AOrlo6
Hmmm,
It seems that I have wrong python in my shell path:
artem@ubuntu:~$ which python
/opt/poky-edison/1.7.2/sysroots/x86_64-pokysdk-linux/usr/bin/python
Community Manager
Hi Thomas1313,
Were you able to import contextlib to python? Also, there's a newer image than edison-src-ww18-15.tgz available here: https://software.intel.com/en-us/iot/hardware/edison/downloads https://software.intel.com/en-us/iot/hardware/edison/downloads in case you want to try it out.
Sergio
AOrlo6
Hi Sergio,
I had an poky toolchain in my $PATH variable from previous installation so python was used from there. I cleared it and bitbake started successfully.
Which download should I use from https://software.intel.com/en-us/iot/hardware/edison/downloads https://software.intel.com/en-us/iot/hardware/edison/downloads to get new edison-src tarball? Unfortunately 'edison-src-ww18-15.tgz' has old poky 1.6.1 toolchain... (((
