when i bitbake edison-image,android.googlesource.com Failed to connect
i don not konw why and how to Solve
please hlep me
thanks!
log:
wq3028@ubuntu:~/edison-bsp/edison-src/out/linux64$ source poky/oe-init-build-env
# Shell environment set up for builds. #
You can now run 'bitbake '
Common targets are:
core-image-minimal
core-image-sato
meta-toolchain
adt-installer
meta-ide-support
You can also run generated qemu images with a command like 'runqemu qemux86'
wq3028@ubuntu:~/edison-bsp/edison-src/out/linux64/build$ bitbake edison-image
Loading cache: 100% |# | ETA: 00:00:00
Loaded 1365 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
Build Configuration:
BB_VERSION = "1.24.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "Ubuntu-14.04"
TARGET_SYS = "i586-poky-linux"
MACHINE = "edison"
DISTRO = "poky-edison"
DISTRO_VERSION = "1.7.2"
TUNE_FEATURES = "m32 core2"
TARGET_FPU = ""
meta
meta-yocto
meta-yocto-bsp = "(detachedfromyocto-1.7.2):29812e61736a95f1de64b3e9ebbb9c646ebd28dd"
meta-intel-edison-bsp
meta-intel-edison-distro = ":"
meta-intel-iot-middleware = "(detachedfromc6d6814):c6d681475e76107e6c04c5f7a06034dc9e772d1e"
meta-intel-arduino = ":"
meta-arduino = "1.6.x:541b127163acb243109f07141bf249da2ecdcd9a"
NOTE: Preparing runqueue
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: Function failed: Fetcher failure: Fetch command failed with exit code 128, output:
fatal: unable to access ' https://android.googlesource.com/platform/external/wpa_supplicant_8/': Failed to connect to android.googlesource.com port 443: Connection refused
ERROR: Logfile of failure stored in: /home/wq3028/edison-bsp/edison-src/out/linux64/build/tmp/work/core2-32-poky-linux/wpa-supplicant/android-4.4.4_r2.0.1-r1/temp/log.do_fetch.10856
Log data follows:
| DEBUG: Executing python function do_fetch
| DEBUG: Executing python function base_do_fetch
| DEBUG: Fetcher accessed the network with the command git -c core.fsyncobjectfiles=0 ls-remote https://android.googlesource.com/platform/external/wpa_supplicant_8 refs/heads/android-4.4.4_r2.0.1 refs/tags/android-4.4.4_r2.0.1^{}
| DEBUG: Running export PATH="/home/wq3028/edison-bsp/edison-src/out/linux64/poky/scripts:/home/wq3028/edison-bsp/edison-src/out/linux64/build/tmp/sysroots/x86_64-linux/usr/bin/i586-poky-linux:/home/wq3028/edison-bsp/edison-src/out/linux64/build/tmp/sysroots/edison/usr/bin/crossscripts:/home/wq3028/edison-bsp/edison-src/out/linux64/build/tmp/sysroots/x86_64-linux/usr/sbin:/home/wq3028/edison-bsp/edison-src/out/linux64/build/tmp/sysroots/x86_64-linux/usr/bin:/home/wq3028/edison-bsp/edison-src/out/linux64/build/tmp/sysroots/x86_64-linux/sbin:/home/wq3028/edison-bsp/edison-src/out/linux64/build/tmp/sysroots/x86_64-linux/bin:/home/wq3028/edison-bsp/edison-src/out/linux64/poky/scripts:/home/wq3028/edison-bsp/edison-src/out/linux64/poky/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"; export HOME="/home/wq3028"; git -c core.fsyncobjectfiles=0 ls-remote https://android.googlesource.com/platform/external/wpa_supplicant_8 refs/heads/android-4.4.4_r2.0.1 refs/tags/android-4.4.4_r2.0.1^{}
| DEBUG: Python function base_do_fetch finished
| DEBUG: Python function do_fetch finished
ERROR: Task 372 (/home/wq3028/edison-bsp/edison-src/meta-intel-edison/meta-intel-edison-distro/recipes-connectivity/wpa_supplicant/wpa-supplicant_android-4.4.4_r2.0.1.bb, do_fetch) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1648 tasks of which 1643 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
Hi Wq3028,
Thanks for your interest in the Intel® Edison Platform.
Could you please provide us the steps or guide you are following? We are requesting it in order to try to help you with your issue. Also, we would like to know if you are trying to customize the image.
We'll be waiting for your reply.
-Yermi A.
Thank you for your help
BSP edison-src-ww25.5-15
ubuntu 1404
I am in accordance with the inter online edison-bsp Guide compiled.
Steps are as follows:
1. Install the prerequisite packages with the following command:
sudo apt-get install build-essential git diffstat gawk chrpath texinfo
libtool gcc-multilib
2. Download the BSP source package edison-src.tgz from the Intel® Edison Software Downloads page. The
package includes the full Yocto environment, and Intel® Edison-specific Yocto recipes to build the image
(including the Linux kernel), a bootloader, and all necessary packages. Download the BSP source package
to your working directory and decompress it.
tar xvf edison-src.tgz
cd edison-src/
3. Use the setup.sh script to initialize the build environment for Intel® Edison.
To create download and sstate directory, you can use mkdir command:
mkdir bitbake_download_dir
mkdir bitbake_sstate_dir
./meta-intel-edison/setup.sh --dl_dir=<=/</span>_to>/bitbake_download_dir
–-sstate_dir=<=/</span>/bitbake_sstate_dir
Optionally, you can move your download and build cache (also called sstate) directories from the default
location under the build directory, using the --dl_dir and --sstate_dir options. Doing this will make it easier
to share this data between build environments, and allow much faster build and download time when
rebuilding the full image, even after a full manual cleanup (by means of deleting everything under your
build directory). To create the sstate directory, use the mkdir command:
4. Configure the shell environment with the source command below. After the command executes, the
directory changes to the edison-src/build folder.
5. Now you are ready to build the full Intel® Edison image with the bitbake command:
Hi Wq3028,
Thanks for all the information provided. We have found information regarding the "Connection Refused" message and it has two main causes: Nothing is listening on the IP: Port you are trying to connect or the port is blocked as it is mention in this link: http://serverfault.com/questions/725262/what-causes-the-connection-refused-message What causes the 'Connection Refused' message?, please take a look at that link and try the suggestions and let us know if it helps, we believe there you will find useful information.
-Yermi A
Hi Wq3028,
We would like to know if you have any updates, and if you checked the link of "What causes the Connection Refused message".
-Yermi A.
