Intel® Makers
9872 Discussions
blue tooth(bulez Stack) customization on Intel edsion
sk23
New Contributor II
Hi ,
I have read the Intel Edison Bluetooth Guide Chapter 6 and it tells me how to unblock the Bluetooth and connect to other devices (bluetoothctl---scan on---connect). I found my BLE device and connected to it successfully.
My ideas is I want to customization blue tooth on Edison. Only my BT sensor need to communicate to the Edison over BT.
Please proved how to customization the bluez stack for Edison.
Community Manager
Hello IoT_srinivas,
I don't understand what you want to achieve, could you please explain us a little bit more about what you would like to do? Nevertheless, if you would like to modify the BlueZ stack, I suggest you to contact BlueZ ( http://www.bluez.org/contact/) as they should be able to provide you more accurate help.
-Peter.
sk23
New Contributor II
Thank you for update Peter.
I want to modify BuleZ stack for Intel Edison.
Community Manager
Hi IoT_srinivas,
As I mentioned, if you would like to modify the BlueZ stack you should refer to BlueZ ( http://www.bluez.org/contact/). They are the developers of the API therefore they should be able to provide you a more accurate support in this regard.
-Peter.
