Intel® Makers
9882 Discussions
boot process stops if a USB peripheral with internal storage is connected
A5601
I have the Compute Stick with Windows 10 and it is connected with USB text writing pad (like wacom)
The writing pad has a built-in storage with preloaded device software and it is recognized as CD-ROM + USB storage under Windows environment.
The boot process won't continue unless the writing pad is disconnected. We tried setting USB boot=Disable in the BIOS but it does not help.
When I select manual boot order, only the Windows partition is available and no sign of CD-ROM.
Any clues? Or there can make permanent changes in the UEFI shell to force boot device order?
Amy_C_Intel
Hello, AE5601:
Could you please be more specific about this behavior. Are you trying to boot from this device?
Amy.
A5601
Hi Amy,
We are trying NOT to boot from the below hand writing pad, which connects permanently to the ICS.
http://sg.penpower.net/product.asp?sn=469 http://sg.penpower.net/product.asp?sn=469
We also did some tests on another hardware platform. System Boot Results as below:
Boot without the hand writing pad
Boot with hand writing pad connected
BIOS: USB Boot = Enable
BIOS: USB Boot = Disable
Intel Compute Stick
With Windows 10
Success
Fail
Success
Dell Optiplex 3020 Micro
Computer, Windows 10
Success
Fail
Fail
The result shows the USB Boot option on the ICS may not work with this device.
Is there any debug information we can provide to you for further investigation?
Thank you.
Amy_C_Intel
USB Boot is mainly used to recover, repair and install an operating system, when you enable the USB Boot on your Intel® Compute Stick means that you are trying to do one of these options which you told me that is not what you want to do. The writing pad is somehow recognized as a booting device therefore the Intel® Compute Stick tries to boot from it but since this is not booting device it fails.
