Hi everyone,
I'm using poky and meta-openembedded(git://git.openembedded.org/meta-openembedded(branch: master))
I want to build metacity and cyrus-sasl(2.1.26) for my SDK
I run the following command
1. I add BBCLASSEXTEND += " nativesdk" to cyrus-sasl_2.1.26.bb
# bitbake nativesdk-cyrus-sasl
but I get error
| x86_64-pokysdk-linux-gcc --sysroot=/poky/build-fw/tmp/work/x86_64-nativesdk-pokysdk-linux/nativesdk-cyrus-sasl/2.1.26-r0/recipe-sysroot -O2 -pipe -Wl,-O1 -o saslauthd mechanisms.o auth_dce.o auth_getpwent.o auth_krb5.o auth_krb4.o auth_pam.o auth_rimap.o auth_httpform.o auth_shadow.o auth_sia.o auth_sasldb.o lak.o auth_ldap.o cache.o cfile.o krbtf.o utils.o ipc_unix.o ipc_doors.o saslauthd-main.o md5.o -lresolv
| auth_getpwent.o: In function `auth_getpwent':
| auth_getpwent.c:(.text+0x42): undefined reference to `crypt'
| auth_shadow.o: In function `auth_shadow':
| auth_shadow.c:(.text+0x109): undefined reference to `crypt'
| collect2: error: ld returned 1 exit status
| Makefile:456: recipe for target 'saslauthd' failed
How can I add -lcrypt to this bb??
2.
I add BBCLASSEXTEND += " nativesdk" to metacity's bb
# bitbake nativesdk-metacity
but I get error
ERROR: Nothing RPROVIDES 'nativesdk-dbus-x11' (but virtual:nativesdk:poky/meta/rec on or otherwise requires it)
ERROR: Nothing RPROVIDES 'nativesdk-dbus-x11' (but virtual:nativesdk:poky/meta/recipes-core/dbus/dbus-glib_0.110.bb RDEPENDS on or otherwise requires it) ERROR: Required build target 'nativesdk-metacity' has no buildable providers. Missing or unbuildable dependency chain was: ['nativesdk-metacity', 'nativesdk-libcanberra', 'nativesdk-pulseaudio', 'nativesdk-gconf', 'nativesdk-dbus-glib', 'nativesdk-dbus-x11']
ERROR: Nothing PROVIDES 'dbus-x11'. Close matches:
dbus RPROVIDES dbus-x11
metacity need dbus-x11
but I cannot find dbus-x11's bb
I cannot see dbus-x11 then run bitbake -s
How can I enable dbus-x11 ??
thanks a lot
John
Hello JohnChiao
Thank you for joining the Intel® community.
Looking into the information that you have shared with us I see that you are developing a personalized system with an embedded configuration, in this case I would advise contacting our Intel® developer zone to create an account (https://software.intel.com/en-us/support https://software.intel.com/en-us/support) go to profile to create an account, also you can visit the Intel® Embedded Community (https://embedded.communities.intel.com/community/en https://embedded.communities.intel.com/community/en) for support with embedded systems.
Thank you.
Leonardo C.
