Community
cancel
Showing results for
Search instead for
Did you mean:
VSine1
building opencv with tbb on Edison
Hello, I am trying to build OpenCV 3.1.0 with TBB following this https://software.intel.com/en-us/articles/opencv-300-beta-ipp-tbb-enabled-on-yocto-with-intel-edison IoT - OpenCV 3.0.0-beta ( IPP & TBB enabled ) on Yocto with Intel® Edison | Intel® Software tutorial. However, .so files that I copied on Edison appeared to be just softlinks and the linker told me that he needed libtbb.so.2, libtbbmalloc.so.2 and libtbbmalloc_proxy.so.2. I found those files in the folder /usr/lib/i386-linux-gnu and copied to Edison. When I tried to build openCV I got the following errors:
/usr/lib/gcc/i586-poky-linux/4.9.1/../../../libtbb.so: undefined reference to `std::range_error::range_error(std::__cxx11::basic_string, std::allocator > const&)@GLIBCXX_3.4.21'
/usr/lib/gcc/i586-poky-linux/4.9.1/../../../libtbb.so: undefined reference to `std::out_of_range::out_of_range(std::__cxx11::basic_string, std::allocator > const&)@GLIBCXX_3.4.21'
/usr/lib/gcc/i586-poky-linux/4.9.1/../../../libtbb.so: undefined reference to `std::length_error::length_error(std::__cxx11::basic_string, std::allocator > const&)@GLIBCXX_3.4.21'
/usr/lib/gcc/i586-poky-linux/4.9.1/../../../libtbb.so: undefined reference to `std::__cxx11::basic_string, std::allocator >::_M_create(unsigned int&, unsigned int)@GLIBCXX_3.4.21'
/usr/lib/gcc/i586-poky-linux/4.9.1/../../../libtbb.so: undefined reference to `std::invalid_argument::invalid_argument(std::__cxx11::basic_string, std::allocator > const&)@GLIBCXX_3.4.21'
/usr/lib/gcc/i586-poky-linux/4.9.1/../../../libtbb.so: undefined reference to `std::runtime_error::runtime_error(std::__cxx11::basic_string, std::allocator > const&)@GLIBCXX_3.4.21'
collect2: error: ld returned 1 exit status
For me it seems like I had to compile those files with g++.
Community Manager
What OS were you using to build this image? What image are you using with the Edison? Did you follow all previous steps on the guide before getting to this point? After running sudo apt-get install libtbb-dev:i386, what are the contents of /usr/include/tbb?
-Sergio
VSine1
I used LinuxMint 18, which, I believe, is equivalent to Ubuntu 16.04. On Edison I have my custom yocto image, but I didn't change much from the default configuration downloaded from the official site https://software.intel.com/en-us/iot/hardware/edison/downloads IoT - Intel® Edison Board Download | Intel® Software .
As I explained, I tried with copying only libtbb.so, libtbbmalloc.so and libtbbmalloc_proxy.so, but this failed, because they were just the softlinks, so I had to search for libtbb.so.2 etc., which I found in /usr/lib/i386-linux-gnu directory on my host-machine.
The contents of /usr/include/tbb are the following:
aggregator.h index.html runtime_loader.h
aligned_space.h internal scalable_allocator.h
atomic.h machine spin_mutex.h
blocked_range.h memory_pool.h spin_rw_mutex.h
blocked_range2d.h mutex.h task.h
blocked_range3d.h null_mutex.h task_arena.h
cache_aligned_allocator.h null_rw_mutex.h task_group.h
combinable.h parallel_do.h task_scheduler_init.h
compat parallel_for.h task_scheduler_observer.h
concurrent_hash_map.h parallel_for_each.h tbb.h
concurrent_lru_cache.h parallel_invoke.h tbb_allocator.h
concurrent_priority_queue.h parallel_reduce.h tbb_config.h
concurrent_queue.h parallel_scan.h tbb_exception.h
concurrent_unordered_map.h parallel_sort.h tbb_machine.h
concurrent_unordered_set.h parallel_while.h tbb_profiling.h
concurrent_vector.h partitioner.h tbb_stddef.h
critical_section.h pipeline.h tbb_thread.h
enumerable_thread_specific.h queuing_mutex.h tbbmalloc_proxy.h
flow_graph.h queuing_rw_mutex.h tick_count.h
flow_graph_opencl_node.h reader_writer_lock.h
global_control.h recursive_mutex.h
By the way, I succeeded by downloading already built tbb from here: https://www.threadingbuildingblocks.org/download Download | Threading Building Blocks
Community Manager
Why are you trying to install OpenCV using this method? I haven't tried this method yet but, as an alternative you can try installing OpenCV from AlexT's repository. You can see instructions on how to configure the repo here http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html .
You can see a discussion about this here /message/394848# 394848 https://communities.intel.com/message/394848# 394848
Let us know your results.
-Sergio
Community Manager
Do you still need help with this thread, were you able to use OpenCV?
-Sergio
Valeriya_S_Intel
Thank you for the suggestion, but unfortunately opencv from AlexT's repository is just 2.4.9, and I needed 3.1.0.
As I said, I managed to install openCV with the pre-built TBB downloaded from offsite, so no further help needed.
Thank you very much for your help.
