Community
cancel
Showing results for
Search instead for
Did you mean:
FerryT
Valued Contributor I
can not find https://communities.intel.com/docs/DOC-23137 (Configuring Edison as AP)
Jump to solution
The title say it all. The link is broken.
Has anyone downloaded that doc and would share it here as attachment?
TIA,
Ferry
FerryT
Thanks Al,
I thought it would be a pdf and called DOC-23137, but I now found this one on archive.org and copied it into LibO.
What happened to the original docs, I see a lot of old Edison docs can still be found in the developer zone, but not this one.
Ferry
