Intel® Makers
9881 Discussions
char to float on intel galileo gen1
JOvie1
I have a char array (matrix), which is a buffer from sound card's ADC.
The problem is that I have to calculate the average of all arrays' value and as it's from sound card's adc it has number from -127 to 127, that is to say that a char fall short. So I have to convert char to float. I do the next:
[code] float average;
for(int i=0; i
for(int j=0; j
average+= (float) buffer [i][j];
average/=(line+colum);
[/code]
Then to know if it's Ok, I keep it in a file and watch it then with security shell.
fprintf(archivo, "%f", average);
where archivo is an FILE type
But it do not work. Why?
How can I convert the buffer values which are char to float? by the way I'm using Intel System Studio IoT
Thanks for yours attention and sorry for my english. If it help I can adjunt the proyect, it's not too large.
Community Manager
Hello julian403,
This short code worked great for me. Test it and let me know if it works for you:
# include
# include
# include
int main()
float value;
char data[20];
strcpy(data, "1234");
value = atof(data);
printf("data value = %s, float value = %f\n", data, value);
return(0);
-Peter.
JOvie1
I did what you said but it did not work. But I changed the compiller from C++ to C (what I really do was create a new proyect in C instead C++) and it works!! but Why? because I'm doing a big proyects and I will have to use C++ because the classes.
what I did it's
float average=0;
float aux;
for(int i=0; i<10; i++)
for(int j=0; j<32;j++)
aux= average;
average= aux+ (float) buffer[i][j]);
So, Im' thinking that that's cast do not work on C++.
Community Manager
I originally thought you were programming on C, that's why my code is in C not C++. The reason why it might have failed on C++ is because the library might not exist on C++.
Nevertheless, this is the equivalent code in C++:
# include
# include
int main ()
char data[] = "1234";
float value;
value = strtof (data, NULL);
printf ("The value of %s in float is: %f \n", data, value);
return 0;
-Peter.
FTinetti
Honored Contributor I
Hi julian403,
What do you mean by "not work"? Did it failed to compile? Did it failed to provide the right result? Other?
Fernando.
JOvie1
[qoute]
[/quote]
It's compile but when I copy it to a file, there is nothing on the file.
FTinetti
julian403 wrote:
[qoute]
[/quote]
I do not understand... would you please explain? Are you using any IDE?
Fernando.
Community Manager
Did neither of those codes helped you? I tested both of them and they worked for me just as expected. I compiled them with the commands gcc string_to_float.c -o string_to_float and g++ string_to_float.cpp -o string_to_float_cpp on C and C++ respectively. I did it directly on Linux, I did not use any IDE.
-Peter.
