I was able to compile Edison image and Installed successfully on target.
Here is the compiling processor for Edison Image.
1- Prepare your workspace:
$ mkdir my_Edison_Workspace
2- Get this layer:
$ git clone git://git.yoctoproject.org/meta-intel-edison
3- Make things easier with 'make':
$ ln -s meta-intel-edison/utils/Makefile.mk Makefile
4- Download all the needed dependencies:
$ make setup
5- Build Intel Edison Yocto distribution:
$ make edison-image
6- Flash the board:
$ make flash
I have binary for kernel version on PC and installed on target.
Only time stamp was updated and kernel remains same(old).
On Target
uname -a
Linux edison 3.10.98-poky-edison+ # 1 SMP PREEMPT Wed Jul 6 12:30:54 IST 2016 i686 GNU/Linux.
I was unable to find the Kernel Source code on PC. How to make kernel source code on pc (local copy).
I want to find the kernel version on compiled source code.
Please provide the details for above questions
Hi iot_srinivas,
Could you please tell us which BSP you are using? It seems like you're using an older version but we would like to know which one. You might not get this issue if you use the latest one.
-Pablo
Do you have updates on this case?
-Pablo
I have same question
I want to modify a file in keral,but I can't find them.
Hi
I took the source code from this link git clone git://git.yoctoproject.org/meta-intel-edison.
I want to modify a file in kernel,but I can't find them.please provide the details.
Hi Srinivas,
Could you please provide us the link where you found those instructions? I would suggest you to follow the instructions from the BSP http://www.intel.com/content/dam/support/us/en/documents/edison/sb/edisonbsp_ug_331188007.pdf http://www.intel.com/content/dam/support/us/en/documents/edison/sb/edisonbsp_ug_331188007.pdf. And download the Edison source package from the Download, under Sources, https://software.intel.com/en-us/iot/hardware/edison/downloads https://software.intel.com/en-us/iot/hardware/edison/downloads, go to Sources – GPL/LGPL source files.
-Pablo
Hi Srinivas,
-Pablo
