Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
configure_edison failure
Jump to solution
Although I have used configure_edison successfully in the past (more than a year ago!), my current attempt fails:
configure_edison --wifi
File "/usr/bin/configure_edison", line 160
print unacceptable_failure % location
SyntaxError: Missing parentheses in call to 'print'
I understand the error message is due to some inadvertent change in the file but I did not edit this file. All parameters (and even none) fail at the same statement. What is my recovery option?
Community Manager
Hello Matha,
Thank you for your interest in the Intel Edison board.
Please make sure you first established a serial connection with the board. You can find the steps here: https://software.intel.com/en-us/setting-up-serial-terminal-on-system-with-linux
If the issue still persists, you might need to reflash the firmware on the board:
https://software.intel.com/en-us/flashing-firmware-on-your-intel-edison-board-linux
Hope this helps.
Octavian
Community Manager
Hello Matha,
Hope this helps.
Octavian
Community Manager
Hello Matha,
Do you require any more assistance with this issue?
Octavian
Community Manager
Hello Octavian,
I am working with you on another thread to flash the firmware. If I can complete your instructions successfully from that thread, I believe I should be able to configure the WiFi as before without any further issue. Please mark this thread as closed.
Thanks again.
