Community
cancel
Showing results for
Search instead for
Did you mean:
JPere36
configure_edison --setup not working
I am using Windows 10 & an Intel Edison Board.
I have flashed my board multiple times with the Yocto 2.0 image, but the configure_edison --setup command always gives me an error and takes me to 'help' instead.
I have been referring to this flashing guide: http://www.intel.com/content/www/us/en/support/boards-and-kits/000005795.html Flashing Intel® Edison (wired)—Windows* for Boards and Kits
The reason I haven't flashed the Yocto 2.1 Image is beacuse whenever i copy it to the Edison, I get a message saying I have run out of memory on the Edison.
I need a solution please.
--Jonathan Pereira.
VJosh4
Hi Jonathan,
The 'configure_edison --setup' command will only work with the 2.1 Yocto update. You can just run 'configure_edison' instead without any parameters on your version and it will bring up the Edison's configuration screen.
The 2.1 Yocto image is too big to perform an update by copying it over to the Edison's mass storage device; you'll have to flash the firmware using Flash Tool Lite. There's instructions on how to do this on the Edison user guide.
Vorn
JPere36
Ok So I followe the steps for Flashing the Latest Yocto Image and I got this error:
01/25/16 09:42:51.560 WARNING: [Port 6/3] Command `C:\Program Files (x86)\Intel\Phone Flash Tool Lite\dfu-util.exe "--alt" "rootfs" "-D" "C:\Users\jonathanrjpereira\Downloads\edison-iotdk-image-280915 (1)\edison-image-edison.ext4" "-t" "4096" "-R" "-d" "8087:0a99"` timed out (1200 s)
01/25/16 09:42:51.560 INFO : [Port 6/3] Retrying `"C:\Program Files (x86)\Intel\Phone Flash Tool Lite\dfu-util.exe" "--alt" "rootfs" "-D" "C:\Users\jonathanrjpereira\Downloads\edison-iotdk-image-280915 (1)\edison-image-edison.ext4" "-t" "4096" "-R" "-d" "8087:0a99"` command
01/25/16 10:02:51.904 ERROR : [Port 6/3] Command `C:\Program Files (x86)\Intel\Phone Flash Tool Lite\dfu-util.exe "--alt" "rootfs" "-D" "C:\Users\jonathanrjpereira\Downloads\edison-iotdk-image-280915 (1)\edison-image-edison.ext4" "-t" "4096" "-R" "-d" "8087:0a99"` timed out (1200 s)
And the flash status: Flash Failed
Diego_V_Intel
Hello jonathanrjpereira,
If you are getting errors when trying to flash the Edison with Flash Tool Lite, I recommend you to try an alternative method to flash the module. The alternative method uses a script called flashall. I recommend you to check the following documents for additional details about flashing the Edison module. You will also find a guide to perform the alternative method:
Diego.
Carlos_M_Intel
Hi Jonathan,
I would like to know if you tried with the methods Diego posted above.
Charlie
