Intel® Makers
9881 Discussions
connect node js with html button
AMura5
hi everyone
i'm working on robot has Intel Edison board and i need to connect the html button and make it a server can anyone help me this is the node code and html code :
app.js:
/*Http server*/
var express = require("express");
var app = express();
var http = require('http').Server(app);
var path = __dirname + '/';
var io = require('socket.io')(http);
var myip = require('quick-local-ip');
var PORT = 4000;
// INTEL EDISON CONTROLL PART----------------------------------------------------
//MRAA Initialization
var m = require("mraa");
var u = new m.Uart(0); //Default
u.setBaudRate(9600);
u.setMode(8,0,1);
u.setFlowcontrol(false, false);
sleep(200);
var command = new Buffer(4);
command[0] = 0x22;
command[1] = 0x00;
command[2] = 0x00;
command[3] = 0x22;
function isObjectClose(threshold) {
var rxBuf;
var result;
u.write(command);
sleep(200);
rxBuf = u.read(4);
sleep(200);
if (rxBuf[3] == (rxBuf[0]+rxBuf[1]+rxBuf[2])) {
result = (rxBuf[1]<<8) | rxBuf[2];
if (result < threshold)
return true;
else
return false;
else
return true;
var x = new m.I2c(0);
x.address(4);
var buf = new Buffer(5);
buf[0] = 0x55; //Header 1
buf[1] = 0xaa; //Header 2
function tankForward(speed) {
if (speed > 0xFF)
speed = 0xFF;
//Left Motor CounterClockwise
buf[2] = 0xB1;
buf[3] = 0x1;
buf[4] = (buf[0]+buf[1]+buf[2]+buf[3]) & 0xFF;
x.write(buf);
//Right Motor CounterClockwise
buf[2] = 0xB2;
buf[3] = 0x1;
x.write(buf);
//Left Motor Speed
buf[2] = 0xC1;
buf[3] = speed;
x.write(buf);
//Right Motor Speed
buf[2] = 0xC2;
buf[3] = speed;
x.write(buf);
function tankBackward(speed) {
if (speed > 0xFF)
speed = 0xFF;
//Left Motor Clockwise
buf[2] = 0xB1;
buf[3] = 0x0;
x.write(buf);
//Right Motor Clockwise
buf[2] = 0xB2;
buf[3] = 0x0;
x.write(buf);
//Left Motor Speed
buf[2] = 0xC1;
buf[3] = speed;
x.write(buf);
//Right Motor Speed
buf[2] = 0xC2;
buf[3] = speed;
x.write(buf);
sleep(2000);
app.get('/', function(req, res){
// console.log(res)
res.sendFile(__dirname + '/index.html');
http.listen(PORT, function(){
console.log('--------------------------------------------------------------');
console.log('-------------------------Loading Server-----------------------');
console.log('--------------------------------------------------------------\n');
console.log('Server IP : '+myip.getLocalIP4()+' Port : '+PORT);
and html is:
<!DOCTYPE html>
Robot as a Website
<!-- make the header for the website to write the name for the project-->
rbot as a websit
<!-- <img src="img/robot.jpg" id="img"> -->
Community Manager
Hello morire,
Thank you for your interest in Intel® Edison Breakout Board.
I understand that you want to program an HTML button that makes the Intel Edison act as a server.
I think this project is more code-oriented than Edison-oriented, in the sense that you are not experiencing any issue with the board itself, which makes your inquiry out of the scope of this technical support team.
What I can do is recommend you a link that may help you turn your Edison into a Webserver using Node.js:
How to Make a Basic Webserver on the Intel® Edison Using Node.js
https://software.intel.com/en-us/videos/how-to-make-a-basic-webserver-on-the-intel-edison-using-node... https://software.intel.com/en-us/videos/how-to-make-a-basic-webserver-on-the-intel-edison-using-node...
Have a nice day.
Andres V.
