Community
cancel
Showing results for
Search instead for
Did you mean:
jbach1
New Contributor II
console.log messages on the edison when running a Nodejs app
Jump to solution
Following this excellent tutorial on remote debugging using Visual Studio with the edison
http://www.codefoster.com/edison-vs/ Using Visual Studio to Write Node for Devices
However, simple question
How do you see any console.log messages on the edison when running a NodeJs app?
My only connection is via an ethernet dongle and I am ssh'ing in to run my node app.
Tags (1)
Carlos_M_Intel
Hi eco_bach
If your script is using the console.log to print outputs you should be able to see the outcome in your Serial Terminal.
For example, if you use this sample (newtest.js):
console.log('Hi echo_bach')
And you run the script with node you will see the outcome in your prompt.
root@Edison:~# node newtest.js
Hi echo_bach
root@Edison:~#
Let me know if this answers your question.
Regards;
CMata
Carlos_M_Intel
Hi eco_bach
Hi echo_bach
root@Edison:~#
Regards;
CMata
jbach1
New Contributor II
Thanks. So it has to ALWAYS be the same session that initiates the node app? Just wondering if there was a way to see the console.log messages from another open session.
