Community
cancel
Showing results for
Search instead for
Did you mean:
ccvet
cooling rotate ?
Jump to solution
Hello I want to know your cooling rotate it? My not running? Is this normal?
AKriz
I'll assume you're referring to the cooling fan? Then that only runs when under processing load, so will not run when it's not needed.
AKriz
ccvet
Thank you very much!
Miguel_C_Old
Hi Rumbaar,
Thank you for your answer.
MiKe C
