Intel® Makers
9880 Discussions
create new files
KSels
New Contributor II
How do I create a new file everytime I ask to start logging data to the sd card and close when asked to stop logging?
my current code recreate the file everytime and all data that was there is gone.
// Create .txt file
var fs = require('fs');
var ws = fs.createWriteStream('/media/sdcard/GPS.txt');
BMass
It seems that fs.createWriteStream() opens the file with write-only access by default ('w')
you should try to specify the append flag 'a' in the options to be able to add data at the end of your log file :
var ws = fs.createWriteStream('/media/sdcard/GPS.txt', {'flags': 'a'});
https://nodejs.org/api/fs.html# fs_fs_createwritestream_path_options File System Node.js v5.3.0 Manual & Documentation
http://stackoverflow.com/questions/3459476/how-to-append-to-a-file-in-node http://stackoverflow.com/questions/3459476/how-to-append-to-a-file-in-node
KSels
New Contributor II
I tryed the flags: a command and it is working, tnx.
Now I only need it to start a new file everytime I press a button, will try to read the links but I am a noob at programming
I was thinking gps_DATE_NR.txt (DD/MM/YY)
For example gps_010216_01.txt
Pedro_M_Intel
Hello KimLorentz,
This script might also be of help for you:
https://github.com/MakersTeam/Edison/blob/master/JavaScript-Examples/NewFilePerDate.js Edison/NewFilePerDate.js at master · MakersTeam/Edison · GitHub
Starting a new file every time you press a button shouldn't be that hard. You will have to set an interruption to stop any process that is running at that time and then capture the data you need in the new file. The mraa library supports interruptions, this is its official example on JavaScript:
https://github.com/intel-iot-devkit/mraa/blob/master/examples/javascript/isr.js mraa/isr.js at master · intel-iot-devkit/mraa · GitHub
Peter.
KSels
New Contributor II
I tryed using the code. But everytime I restart the javascript it only restart logging on the same file, it does not start a new one.
var dat = new Date();
var day = dat.getDate();
var month = dat.getMonth() + 1;
var year = dat.getFullYear();
var fn = "";
var files = fs.readdirSync(__dirname);
var fillen = files.length - 1;
var ac = [];
var rd = day + "_" + month + "_" + year;
fn = rd + "_1";
var bc = fn.split('');
var gen = false;
var mf = 0;
for(var c = 0; c < fillen; c++)
if(gen == true)
if(mf < ac[bc.length-1])
mf = parseInt(ac[(bc.length - 1)]);
gen = false;
ac = files[c].split('');
for(var c1 = 0; c1 < (bc.length - 1); c1++)
if(ac.length != bc.length)
break;
if(ac[c1] != bc[c1])
break;
else
if(ac[bc.length-2] == bc[(bc.length - 2)])
gen = true;
break;
var fnam = rd + "_" + (mf+1);
var ws = fs.createWriteStream('/media/sdcard/' + fnam + '.txt');
console.log(fnam);
//ws.end();
setInterval(function()
console.log('Write to sd card');
console.log(fnam);
ws.write('test' + '\n');
}, 500);
Pedro_M_Intel
Hi KimLorentz,
I found the issue in the code and updated the source, there was an "=" missing on line 28 (15 in your post). It should work without issue now. The issue was that the script would not work unless there was another file in the directory, it should be resolved now but let me know.
Peter.
KSels
New Contributor II
I tryed the new code, still not working.
I want to save to sd card on media and not on Edison
var fn = "";
var ac = [];
fn = rd + "_1";
var gen = false;
var mf = 0;
for(var c = 0; c <= fillen; c++)
if(gen == true)
gen = false;
break;
break;
else
gen = true;
break;
var fnam = '/media/sdcard/'+ rd + "_" + (mf+1) + '.txt';
var ws = fs.createWriteStream(fnam);
//ws.write('test' + '/n');
//console.log(fnam);
//ws.end();
console.log(fnam);
}, 500);
Pedro_M_Intel
Have you tried running the script from the SD card? The script creates the new files in the directory it is stored, the line you modified, 38 in your last post, won't change the place where it is stored, it would only modify the name of the file.
I noticed you added some lines, what do you want to achieve with that modification? I might be able to help you.
Peter.
