Intel® Makers
9880 Discussions
custom (Seperate) palpitation for Intel Edison
sk23
New Contributor II
I want to use different palpitation for Intel Edison. One for Bios/Firmware and One for user programs.
My idea is we need to separate BIOS and/or Root fs and User programs.It is similar to micro kernel architecture.
If something is wrong in firmware or user program Still device should work with Linux services(BIOS/Rootfs).
Please provide the details how make custom partition on yocto linux.
Logs
configure_edison --version
Could not determine firmware version information. Quitting.
none
root@edison:~# cat /proc/version
Linux version 3.10.17-poky-edison+ (neck@iotdk-ninja) (gcc version 4.9.1 (GCC) ) # 2 SMP PREEMPT Mon Mar 14 15:26:16 PDT 2016
/thread/67295 https://communities.intel.com/thread/67295
root@edison:~# cat /proc/meminfo
MemTotal: 983100 kB
MemFree: 739836 kB
Buffers: 15752 kB
Cached: 176404 kB
SwapCached: 0 kB
Active: 86088 kB
Inactive: 116544 kB
Active(anon): 12468 kB
Inactive(anon): 49700 kB
Active(file): 73620 kB
Inactive(file): 66844 kB
Unevictable: 0 kB
Mlocked: 0 kB
HighTotal: 123912 kB
HighFree: 5780 kB
LowTotal: 859188 kB
LowFree: 734056 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Dirty: 0 kB
Writeback: 0 kB
AnonPages: 10476 kB
Mapped: 15032 kB
Shmem: 51700 kB
Slab: 29588 kB
SReclaimable: 20356 kB
SUnreclaim: 9232 kB
KernelStack: 936 kB
PageTables: 824 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 491548 kB
Committed_AS: 193232 kB
VmallocTotal: 122880 kB
VmallocUsed: 8428 kB
VmallocChunk: 112740 kB
DirectMap4k: 10232 kB
DirectMap2M: 870400 kB
Community Manager
Hello IoT_srinivas,
I don't understand what you mean by "...different palpitation for Intel Edison…" Could you please explain what you mean by palpitation?
You mention custom partitions, are you referring to that? If that's not the case and you only need to modify the Edison's partitions, I suggest you to read the following thread where David Hunt explains how to repartition the Edison with the flashall script:
https://communities.intel.com/message/257617# 257617 https://communities.intel.com/message/257617# 257617
-Peter.
sk23
New Contributor II
Hi ,
I want custom partitions on sd card .Intel Edison boot form SD card.
If SD card not available Edsion should boot from EMMC.(on board memory).
Please provide the complete script and details.How to make partitions on sd and how to load the roots fs ,boot and etc)
Previous there is not much useful.
sk23
New Contributor II
intel_corp
I want to use different partitions for Intel Edison. One for Bios/Firmware and One for user programs.
My idea is we need to separate BIOS and/or Root fs and user programs.It is similar to micro kernel architecture.
sk23
New Contributor II
Hi Intel BSP team,
I want custom partitions on sd card and Intel Edison boot form SD card.
Please provide the complete script and details.How to make partitions on sd and how to load the roots fs ,boot and bios into Sd card.
Previous thread is not much useful.
Community Manager
I think I now understand you. You would like to either boot from SD card or from eMMc, right? If so, then I believe my suggestion in https://communities.intel.com/thread/103306 https://communities.intel.com/thread/103306 should be able to help you.
-Peter.
