Community
cancel
Showing results for
Search instead for
Did you mean:
MAl-m3
devkit-launcher.bat in my iotdk doesn't work on windows 10 x64 bit ..please any help!
Hello guys I'm using windows 10 x64 bit and when I download iotdk-ide-win and launch devkit-launcher.bat it give me this error, what I should do?
Community Manager
Hello Momani,
The last time I installed Eclipse on my PC (Windows 7 64-bit) I experienced the same issue. The workaround that finally made Eclipse work again was to put all the IDE's files in C:\Windows\System32. Why don't you try this?
Take the IDE's file and decompress it into System32, make sure you don't decompress it into a subfolder within System32. Then start devkit-launcher.bat with Admin rights and it should work.
Peter.
Community Manager
Hi Momani,
Did you tried with Peter's suggestion? Has you been able to run Eclipse on your PC?
Charlie
