Hello pakote,
Thank you for joining the Intel communities.
Try accessing the BIOS and under configuration make sure the SD card option is enabled.
Also you can check the tested peripherals at the following link, at that link you can see the MicroSD Cards tested with this Intel® Compute Stick.
http://www.intel.com/support/motherboards/desktop/sb/CS-035408.htm Intel® Compute Stick — Tested Peripherals
Regards!
Ivan
