Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
edison I2C
Hi ,
I have 4 devices on an I2C bus. These devices detect on arduino in 100khz and 400khz modes.
I have used a scope and minimised the skew on the edges by changing the pullup resistors.
2k seams to be the optimum.
i am using mraa to try to write data to the non-detected chip and it fails to write.
I can succesfuly wite to the other devices on the bus with this code.
mraa_i2c_address(i2c, 0x50); // device address
mraa_i2c_write(i2c,reg, 2); // write 2 x byte reg address
mraa_i2c_write(i2c,data,buffersize); // send buffer out the port
I have a programmer for this chip that does detect it if I plug it in and i succesfuly programs this DSP chip.
chip address is 0x38
I can write to other chips on the bus with mrra succesfuly. the eprom at 0x50 writes succesfuly.
I am using i2cdetect -r -y -a 6 to scan bus 6 on the edison arduino breakout board and the 3 other ic's on the bus detect.
I am ussuming the failed write to the DSP ic is becasue it is not detecting?
I'll upload the scope image of the edges working on the write to the eprom if anyone thinks that will help but they look good enough to me.
Can anyone think of something i'm missing out on here ? I would love to finish this project with the edison but have got stuck here !
Are there known problems in mraa with multiple devices ? is the edison I2C bus week or slow ? I am am using bus 06 and not bus 01
I read bus 01 does'nt get multiplexed on arduino breakout board or something for mraa.
I can see the attempted wtires to 0x38 on my scope but nothing is returned.
[ update ]
I flashed Edison with latest firmware
then update like this.
opkg update
opkg upgrade
and still no 0x38 device detects.
The bus capacitance is approx 40 - 50pf and I am running the edison at the stadard 400khz i2c speed. I have not tried re-building
the edison firmware for 100khz I2C SCL clock. The device at 0x38 is good for 400khz in its datasheet.
[ / end update ]
my mraa test code below works with another device on the bus. In fact the other three devices on the bus are working.
does anyone have an image I could download that has the 100khz enabled for edison I could try? I dought it will help since
the edges look good enough at 400khz.
I tried using isoproponol to clean the board in case there was some additional capacitance but I
have been told 50pf should be fine anyway for 4 devices on an I2C bus.
Any ideas would be much welcome as my project is stuck at this point.
send junk out the I2c port for testing
# include
# include
# include
# include // for usleep microseconds delay
int main()
// check that we are running on Galileo or Edison or Joule
mraa::Platform platform = mraa::getPlatformType();
if((platform != mraa::INTEL_GALILEO_GEN1) &&
(platform != mraa::INTEL_GALILEO_GEN2) &&
(platform != mraa::INTEL_EDISON_FAB_C) &&
(platform != mraa::INTEL_GT_TUCHUCK)) {
std::cerr << "Unsupported platform, exiting" << std::endl;
return mraa::ERROR_INVALID_PLATFORM;
unsigned char reg[2];
unsigned char data[128]; //junk bytes
mraa_i2c_context i2c;
i2c = mraa_i2c_init(0);
mraa_init();
// 2 byte reg address for write location
reg[0] = 0x00;
reg[1] = 0x01;
for(int z=0;z<10;z++)
data[z] = z;
mraa_i2c_write(i2c,data,9); // send it out the port
mraa_i2c_stop(i2c); // stop i2c
usleep(1000000);
return mraa::SUCCESS;
Tags (1)
ttrip
On which board do you work ?
For the mini , i use the I2C line as follow :
- path to set the speed of line i2c-1 : /sys/devices/pci0000:00/0000:00:08.0/i2c_dw_sysnode/mode
- path to set the speed of line i2c-6 : /sys/devices/pci0000:00/0000:00:09.1/i2c_dw_sysnode/mode
so, to check a line, exemple i2c-1 :
cat /sys/devices/pci0000:00/0000:00:08.0/i2c_dw_sysnode/mode
now, if i remember ,3 modes are availables, (need to recheck the datasheet for corresponding speed):
-STD , 100 khz
-FAST, 375 khz
-HIGH, 385 khz
to set standard mode on line, exemple i2c-6:
echo "std " > /sys/devices/pci0000:00/0000:00:09.1/i2c_dw_sysnode/mode
to set fast mode, line i2c-6:
echo "fast " > /sys/devices/pci0000:00/0000:00:09.1/i2c_dw_sysnode/mode
Community Manager
Wow , thanks toukytrip !
I'm using the arduino breakout board. I'll be using the mini breakout board later if I get this to work !
I changed the speed to 100khz succesfuly with echo "std " > /sys/devices/pci0000:00/0000:00:09.1/i2c_dw_sysnode/mode
unfortunately 0x38 still does not detect.
the edge here should be fast enough ?
100khz scl
I'll play around with the pullups again and see if there is a way to get the rise time any quicker.
any other ideas , things I could try ?
this output was from i2cdetect -r -a -y 6
I took off one componant ( the eprom 0x50 ) to reduce the part count to 3 but still 0x38 returns nothing !
Community Manager
could it be the rise is to slow? The max rise time for the part is 300 ns in the data sheet for 400khz SCL.
is I2C rise time calculated from 0v - VCC or to whatever the logic level on is? ( maybe 1/2 vcc ? or 1v ? )
maybe I should take another look at the arduino rise time and see if its any quicker.
I'm getting similar edge rise time on 400khz, about 500ns to VCC or 250ns to logic level on. I was thinking slowing down the SCL would make the part more forgiving of the 500 ns rise time.
Maybe i'm not looking at the wrong thing here and i'm missed something ?
Community Manager
Hi bennnn,
Thanks for reaching out.
That's a weird issue. According to the information about I2C (Section 4.2) of the Edison Hardware Guide: http://www.intel.com/content/www/us/en/support/boards-and-kits/000005808.html, it shouldn't have problems with the rise time, so I think that it isn't the problem.
When a I2C device is not detected, we normally recommend to the users to supply the I2C sensors with an external power supply, so you can try it and let us know if it works.
Have a nice day.
Leonardo R.
Community Manager
Hi Leonardo,
The part is running on its own power , 3.3v logic level set on IOVDD pins.
It detects with arduino uno and logic level shifter and with similar rise times so I think your right it must be something
else.
I can change the address of the chip. last two bits of the 7 bit address with jumpers but still not detected. the 8th bit sets read / write.
if I use i2cdump 6 0x38 I get nothing.
I have tried without external pullups to set the internal pullups at 2k.
cd /sys/kernel/debug/gpio_debug/gpio27
echo "2k" > current_pullstrength
cd /sys/kernel/debug/gpio_debug/gpio28
I have tried using external pullups with differnt resistance ( 2k seams to give the best edge and works best with other devices on bus )
echo "50k" > current_pullstrength
I have tried using pullups to 3.3v frm edison arduino board and my own 3.3v on device board. no I am using none with 2k pullup set on the edison.
Can you think of anything else I can try ?
ttrip
bennnn,
Maybe check the pinmode ? need set to "mode1"....
cat /sys/kernel/debug/gpio_debug/gpio27/current_pinmux
cat /sys/kernel/debug/gpio_debug/gpio28/current_pinmux
echo "mode1" > /sys/kernel/debug/gpio_debug/gpio27/current_pinmux
echo "mode1" > /sys/kernel/debug/gpio_debug/gpio28/current_pinmux
Community Manager
nope.. pinmux is mode1
Community Manager
Hi bennnn,
That's weird, We will investigate more about it, and I'll let you know when we have updates.
Have a nice day.
Leonardo R.
Community Manager
Hi Bennnn,
Have you tried to connect only the I2C device directly to the Edison? Please try it without any other device and without the logic level translator. There have been cases where the logic level translator is the root cause but I don't think this is the case, but you can try it.
We also found this thread: https://communities.intel.com/thread/104994 https://communities.intel.com/thread/104994, this user had a similar issue, and he found a workaround to make it work using the MCU. It might work for you too.
I hope you find this useful.
Have a nice day.
Leonardo R.
Community Manager
Hi Leonardo,
I'm only using the i2c level level translator on the arduino Uno. The parts are 3.3v logic so fine direct to edison intel arduino breakout set to 3.3v
I will hook up the 0x38 I2c part direct to edison with lab power supply and adpater board when I get time and post results here.
I'm not sure this will make a differnce since all the parts detect on both arduino Due and Uno ( one is atmega and other is ARM cpu so differnt platforms )
thanks for the link to the lower level code ( mcu library workaround ) I'll try it if I can understand it !
If that works then maybe the problem is with mraa library?
Community Manager
Hi Bennnn,
Great! Let us know when you have updates about this.
And, I don't think it is a problem with MRAA, because you don't have issues with the other devices that you are using.
We will be waiting for your updates.
Leonardo R.
Community Manager
Hi bennnn,
Do you have any updates about this?
Leonardo R.
Community Manager
hi, I'm trying to build the code in the MCU SDK eclipse. It builds and sppears to run ,but no messages on the consile and no binaries are built for me to run on the Ediosn. the 0x38 device detects without any issues on arduino UNO ( atmel ) and arduino DUE ( arm ) on my 3 i2c part design soreally no point in putting together a single chip test of the one 0x38 device. If I can't use it with other devices then I can't usethe Edison. ok, before I do more work on running the MCU SDK code , I found this.https://software.intel.com/en-us/node/545142 Creating applications with the MCU SDK for the Intel® Edison board | Intel® Software if you look at the known limitations it rules out a few things for me. 1, My application will also need 1 x SPI port. 2, "The maximum message size for interprocess communication between the CPU and the MCU is currently limited to 255 bytes."There is 256 byte limit on I2C byte transfer? I have more than this to be loaded to My DSP. Nearer 4008 bytes in chunks. there are a series of scipts I should upload in order to setup GPIO for possibe testing with MCU SDK, but in the instructions it olnly talk about CYGWIN example.I am on OSX and I can't find the scripts. Unless the 'Known Limitations' note are out of date then it seams the MCU SDK is another rabbit hole that not going to get me very far anyone any other ideas ? is there something wrong with the Intel Edison I2C implimentation ? Anyone else having trouble detecting multiple standard 7bit I2C addressed devices with Edison ?
Community Manager
Hi bennnn,
There have been some users with issues detecting I2C sensors, and we are not sure why this happens. I gave you the MCU suggestion because it worked for some users, and I thought that it might be helpful for you.
Unfortunately, we don't have some sensors to test them and validate them.
If you find a way to solve this, please feel free to post it here, it would be very useful for the community.
Leonardo R.
