I fear my edison is bricked:
flashall and flashall --recovery failed so I tried
/usr/bin/platformflashtoollite
06/16/18 00:34:38.923 INFO : Intel(R) Platform Flash Tool Lite V 5.8.4.0 x64 (build on Tuesday May 02nd 2017, 13:20:36 UTC)
06/16/18 00:34:38.923 INFO : Using xFSTK Downloader version: 2.0.0
06/16/18 00:34:38.933 INFO : Using DFU Downloader version: 0.8.4
06/16/18 00:34:38.934 INFO : Using DnX Firmware Downloader version: 1.0.0.0 (API: 3.0.20.1171(DBG))
06/16/18 00:34:39.004 INFO : Using Intel Command Line FlashTool v.2.64 (Download Library v.5.31)
06/16/18 00:34:39.012 INFO : Using Android Debug Bridge version 1.0.39
Revision 3db08f2c6889-android
Installed as /opt/intel/platformflashtoollite/bin/adb
06/16/18 00:34:39.012 INFO : No external tool registered
06/16/18 00:34:39.210 INFO : OS version detected: Linux x64 (Ubuntu 18.04 LTS)
06/16/18 00:34:39.229 INFO : SSL supported: Yes
06/16/18 00:34:39.242 INFO : Disk space available on /tmp : 17.41 GB
06/16/18 00:34:39.251 INFO : Adb and fastboot binaries OK
06/16/18 00:34:40.418 INFO : Platform Flash Tool Lite initialized successfully
06/16/18 00:34:52.070 INFO : Ready to flash!
06/16/18 00:34:52.073 INFO : Flash file /home/philippe/.flasher/.download/Edison_Poky_16-06.zip/FlashEdison.json [Windows] loaded
06/16/18 00:34:54.368 INFO : [Port -1] Starting flash ...
06/16/18 00:34:54.368 INFO : [Port -1] Running `Notify ${helperFile}` command
06/16/18 00:34:54.428 INFO : Displaying notification during 42000 ms
06/16/18 00:34:54.432 INFO : [Port -1] Command `Notify ${helperFile}` succeed
06/16/18 00:34:54.432 INFO : [Port -1] Running `Wait for device with status dnx_fw on port -1` command
06/16/18 00:35:01.441 INFO : [Port 1/5] Command `Wait for device with status dnx_fw on port -1` succeed
06/16/18 00:35:01.441 INFO : [Port 1/5] Running `Notify Edison board plugged` command
06/16/18 00:35:01.442 INFO : [Port 1/5] New device detected on 1/5 (id=0104000000000001)
06/16/18 00:35:01.474 INFO : Displaying notification during 5000 ms
06/16/18 00:35:01.477 INFO : [Port 1/5] Command `Notify Edison board plugged` succeed
06/16/18 00:35:01.477 INFO : [Port 1/5] Running `"/opt/intel/platformflashtoollite/bin/xfstkFlashTool" "-1" "/home/philippe/.flasher/.download/Edison_Poky_16-06.zip/edison_dnx_fwr.bin" "/home/philippe/.flasher/.download/Edison_Poky_16-06.zip/edison_ifwi-dbg-00.bin" "/home/philippe/.flasher/.download/Edison_Poky_16-06.zip/edison_dnx_osr.bin" "/home/philippe/.flasher/.download/Edison_Poky_16-06.zip/u-boot-edison.img" "0x80000007" "none" "none" "0"` command
06/16/18 00:35:01.488 INFO : [Port 1/5] Disabling xFSTK Misc DnX
06/16/18 00:35:01.489 INFO : [Port 1/5] Disabling xFSTK wipe out ifwi option
06/16/18 00:35:01.489 INFO : [Port 1/5] Using xFSTK Solo interface (new API)
06/16/18 00:35:01.489 INFO : [Port 1/5] xFSTK Soft Fuse not set
06/16/18 00:35:01.489 INFO : [Port 1/5] XFSTK Downloader API 2.0.0
06/16/18 00:35:01.489 INFO : [Port 1/5] Copyright (c) 2015 Intel Corporation
06/16/18 00:35:01.489 INFO : [Port 1/5] fwdnx -- /home/philippe/.flasher/.download/Edison_Poky_16-06.zip/edison_dnx_fwr.bin
06/16/18 00:35:01.489 INFO : [Port 1/5] fwimage -- /home/philippe/.flasher/.download/Edison_Poky_16-06.zip/edison_ifwi-dbg-00.bin
06/16/18 00:35:01.489 INFO : [Port 1/5] osdnx -- /home/philippe/.flasher/.download/Edison_Poky_16-06.zip/edison_dnx_osr.bin
06/16/18 00:35:01.489 INFO : [Port 1/5] osimage -- /home/philippe/.flasher/.download/Edison_Poky_16-06.zip/u-boot-edison.img
06/16/18 00:35:01.489 INFO : [Port 1/5] gpflags -- 0x80000007
06/16/18 00:35:01.489 INFO : [Port 1/5] softfuse --
06/16/18 00:35:04.109 INFO : [Port 1/5] ....XFSTK-LOG--virtual bool MerrifieldDownloader::SetDevice(IGenericDevice*)
06/16/18 00:35:04.109 INFO : [Port 1/5] Initiating download...
06/16/18 00:35:04.146 INFO : [Port 1/5] XFSTK-STATUS--FW(Miscdnx) download is in progress ...
06/16/18 00:35:04.147 INFO : [Port 1/5] ...
Hello Phil,
Thank you for your interest in Intel® Edison Board.
Does the USB serial port appear on your PC's device manager under Ports(COM & LPT)?
Are you able to enter your Edison OS?
You can try to flash it using the Flash Tool Lite.
If using the Flash Tool Lite will not work, you can use the Flashall method; you can find an explanation in the link below: /message/311395# 311395 https://communities.intel.com/message/311395# 311395
Also, if the previous methods are not helping you can try the method mentioned in /message/257171# 257171 https://communities.intel.com/message/257171# 257171.
This method can be used only on a PC with Linux OS.
We suggest you try these methods and let us know the result.
George
Intel Customer Support
yes I see it under /dev/ttyUSB something (linux)
> Are you able to enter your Edison OS? no
I tried this and it failed with the above message
flash-all --recovery is same as flash tool lite no ?
This is what I use... I can share more logs06/16/18 01:33:25.300 DEBUG : [Port 1/5] XFSTK-LOG--virtual bool MerrifieldUSB20Device::Write(void*, unsigned int) --->DnER 06/16/18 01:33:29.882 DEBUG : [Port 1/5] XFSTK-LOG--GetOpCode 06/16/18 01:33:29.882 DEBUG : [Port 1/5] XFSTK-LOG--ReadInAck 06/16/18 01:33:29.886 DEBUG : [Port 1/5] XFSTK-LOG--usb_bulk_read() fails 06/16/18 01:33:29.890 DEBUG : [Port 1/5] XFSTK-LOG--usb_bulk_read() fails 06/16/18 01:33:29.895 DEBUG : [Port 1/5] XFSTK-LOG--usb_bulk_read() fails 06/16/18 01:33:29.899 DEBUG : [Port 1/5] XFSTK-LOG--usb_bulk_read() fails 06/16/18 01:33:29.903 DEBUG : [Port 1/5] XFSTK-LOG--usb_bulk_read() fails 06/16/18 01:33:29.907 DEBUG : [Port 1/5] XFSTK-LOG--usb_bulk_read() fails 06/16/18 01:33:29.907 DEBUG : [Port 1/5] XFSTK-LOG--USB I/O ERROR RETRYING R/W 06/16/18 01:33:29.907 DEBUG : [Port 1/5] XFSTK-LOG--LogError 06/16/18 01:33:29.908 WARNING: [Port 1/5] XFSTK-STATUS--Error Code: 4 - Error attempting to read ACK/NACK from IN Pipe
