Hi everyone,
I got my edison bricked and now I can not falsh it properly.
I'm following/thread/56121 this link to recover my edison.
but the problem is, when i run the last command, (i.e ./package-xfstk-downloader-linux.sh ) it gives me the following error:
g++: error: /usr/lib/libusb.a: No such file or directory
make[4]: *** [../../../xfstk-build/bin/debug/downloader-solo/xfstk-dldr-solo] Error 1
make[4]: Leaving directory `/home/x3/Downloads/xfstk-build/linux-source-package/xfstk-projects/core/downloader-solo'
make[3]: *** [debug-all] Error 2
make[3]: Leaving directory `/home/x3/Downloads/xfstk-build/linux-source-package/xfstk-projects/core/downloader-solo'
make[2]: *** [sub-downloader-solo-make_default-ordered] Error 2
make[2]: Leaving directory `/home/x3/Downloads/xfstk-build/linux-source-package/xfstk-projects/core'
make[1]: *** [sub-core-make_default-ordered] Error 2
make[1]: Leaving directory `/home/x3/Downloads/xfstk-build/linux-source-package/xfstk-projects'
make: *** [sub-xfstk-projects-make_default-ordered] Error 2
make: Leaving directory `/home/x3/Downloads/xfstk-build/linux-source-package'
ERROR: make -w step problem
now how should i proceed in order to recover my bricked edison ??
Hello mailto:falak.desai@yahoo.com falak.desai@yahoo.com,
If your board is bricked then, there are a few ways to try to recover it. I would try them in the following order:
Flash Tool Lite:
https://software.intel.com/en-us/iot/hardware/edison/downloads IoT - Intel® Edison Board Download | Intel® Developer Zone
(You will find the tool and a guide on how to use it there)
Flashall:
Recovery:
(This one is the one you've already tried)
If you haven't tested the other options yet, do it and let us know what happens.
Peter.
Hi Falak,
Have you been able to use again your board?
Did you follow the suggestions from Peter?
Charlie
hi CMata_Intel
yes, I got that solved from/thread/56121 this link only.
i had some issues but than Mhahn helped me out.
