Intel® Makers
9874 Discussions
edison does not boot after successful flashed
skais
Hello all,
I have flashed my edison successfully (after some troubles), but now the sucessful story stops: edison does not boot at. I can power it successfully as USB stick, (only at the appropriate usb entry. )
I flashed it by using both usb entries, it does not work by using the power supply, - no led at all that lights up.
The usb stick works successfully, I can download and retrieve files, but thats all. To open a screen ist not possible, there is only one ttyUSB open.
When I push the reset button , the both leds that light(DS2 and DS3) switch off and on again, but that ist all that is possible.
Can anybody help me?
Thanx
Siegfried
Diego_V_Intel
Hello siegfried,
I recommend you to try to flash the board with the flashall method. This is an alternative method that might resolve the issue. Please check the following guide where there are steps to perform the flashall method:
On the other hand, I'm concerned about the power supply. When you power the board using the DC power supply, does it work or the board remains without activity?
Diego.
Carlos_M_Intel
Hi siegfried,
Did you try with the flashall script?
Do you have updates on this?
Charlie
