Intel® Makers
9874 Discussions
edison gps longitude latitude parsing..
hlim12
hi, These days, I am developing a GPS with Intel Edison. However, there are some problems.
Is there a way I want to import only the GPS latitude and longitude value?
$GPGGA,113731.000,3509.2693,N,12805.5830,E,1,5,2.37,49.0,M,23.9,M,,*6D
$GPGSA,A,3,02,193,07,05,29,,,,,,,,2.55,2.37,0.94*3B
$GPGSV,3,1,11,193,78,059,19,02,73,118,16,05,64,332,17,13,54,200,*40
$GPGSV,3,2,11,29,34,298,17,06,28,126,,30,25,090,,20,23,281,*7D
$GPGSV,3,3,11,15,22,221,,07,20,062,22,19,01,166,*45
$GPRMC,113731.000,A,3509.2693,N,12805.5830,E,0.00,354.34,030816,,,A*60
"3509.2693, N, 12805.5830,E" I want to bring value..
eclipse and c++ using..
I will thank you attach the answer.
Community Manager
The easiest way is to use gpsd:
(1) Setup opkg to access AlexT's Repo:
open /etc/opkg/base-feeds.conf with nano and edit it:
src/gz all http://repo.opkg.net/edison/repo/all http://repo.opkg.net/edison/repo/all
src/gz edison http://repo.opkg.net/edison/repo/edison http://repo.opkg.net/edison/repo/edison
src/gz core2-32 http://repo.opkg.net/edison/repo/core2-32 http://repo.opkg.net/edison/repo/core2-32
(2) run opkg update
(3) opkg install gpsd
To test the gps:
(4) opkg install gps-utils
(5) disable the gpsd systemd service (don't know if this is really important):
systemctl stop gpsd.socket
systemctl disable gpsd.socket
(if you want to restart them:
systemctl enable gpsd.socket
systemctl start gpsd.socket
(6) start gpsd with your serial port, example:
gpsd /dev/ttyMFD1 -F /var/run/gpsd.sock
(7) try gps
cgps -s
I used gpsd with node.js: npm install node-gpsd
For C language you can use this links:
http://stackoverflow.com/questions/32000328/libgps-c-code-example gps - libgps C code example - Stack Overflow
http://catb.org/gpsd/client-howto.html GPSD Client HOWTO
Have Fun
Flo1991
Community Manager
(2) run opkg update
To test the gps:
(7) try gps
cgps -s
Have Fun
Flo1991
hlim12
thank you!!..
Intel Edison is for beginners... i sad..
I did not exactly understand the answer above.
Um... Can you explain in more detail?
Installation instructions,
src / gz all http://repo.opkg.net/edison/repo/all
src / gz edison http://repo.opkg.net/edison/repo/edison
src / gz core2-32 http://repo.opkg.net/edison/repo/core2-32
What is that to them?, How to install? etc.
Community Manager
Refering to this: http://alextgalileo.altervista.org/edison-package-repo-configuration-instructions.html Edison Package Repo Configuration Instructions
nano /etc/opkg/base-feeds.conf
nano (a simple texteditor) opens the file, edit the file to:
save the changes and exit.
(2):
opkg update
... and so on
Flo1991
