Intel® Makers
9881 Discussions
edison-image unavailable to bitbake
SDijk
I'm following the http://download.intel.com/support/edison/sb/edisonbsp_ug_331188007.pdf BSP user guide and trying to compile my first image. When I run `bitbake edison-image`, I get an error: Nothing PROVIDES 'edison-image'. How to proceed?
SDijk
Fixed by starting all over, not sure what went wrong in my first attempt.
SDijk
Sergio_A_Intel
Are you adding any third party packages to the image? In what OS are you running these tests? What is the complete error message you receive? What previous steps from the guide have you followed?
EDIT: I noticed you already have found the solution for your question. In the future, if you have any other questions don't hesitate to contact us.
Sergio
TCars
I'm having this same problem, I tried doing all the steps again, but to no avail.
I'm trying to build basic image before I add other packages. At this point I have not.
I'm using poky 1.7.2 , Ubuntu 14.04 64 bit and this is the error message:
me@mycomputer:~/poky/edison-src/build$ bitbake edison-image
Parsing recipes: 100% |# | Time: 00:00:54
Parsing of 891 .bb files complete (0 cached, 891 parsed). 1287 targets, 40 skipped, 0 masked, 0 errors.
ERROR: Nothing PROVIDES 'edison-image'
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
I can post all the steps I did if this isn't enough...
Sergio_A_Intel
Hi Tayc,
Yes, please post all the steps you followed prior to this error.
Sergio
TCars
This is everything I have @Intel_Alvarado
I used git to clone poky, downloaded the edison-src file and extracted it using tar. prior to this I had made a test image using poky for qemux86 and it built and ran
Edit: some of the lines had mushed together so I tried to separate threm
god@dv6:~/poky$ cd edison-src/
god@dv6:~/poky/edison-src$ mkdir bb_dl_dir && mkdirbb_ss_dir
mkdirbb_ss_dir: command not found
god@dv6:~/poky/edison-src$ mkdir bb_dl_dir && mkdir bb_ss_dir
mkdir: cannot create directory 'bb_dl_dir': File exists
god@dv6:~/poky/edison-src$ ./meta-intel-edison/setup.sh --dl_dir=/home/god/poky/edison-src/bb_dl_dir --sstate_dir=/home/god/poky/edison-src/bb_ss_dir
ERROR: '/home/god/poky/edison-src/bb_ss_dir' directory does not exist
Setup build environment for building the Edison Device Software
./setup.sh
-h --help display this help and exit
--dl_dir=/home/god/poky/edison-src/bb_dl_dir define the directory (absolute path) where bitbake places downloaded files
--sstate_dir=/home/god/poky/edison-src/bbcache/sstate-cache define the directory (absolute path) where bitbake places shared-state files
--bb_number_thread=4 define how many tasks bitbake should run in parallel
--parallel_make=4 define how many processes make should run in parallel when running compile tasks
--mode=external define whether we are working in development mode, i.e. with local version of the yocto recipes. Possible values are 'devenv' for setupping a development environment and 'external' for a regular build.
--build_name=Custom Edison build by god@dv6 2015-11-03 08:17:11 EST defines custom build name which can then be retrieved on a running linux in /etc/version
--sdk_host=linux64 choose host machine on which the generated SDK and cross compiler will be run. Must be one of [linux32 linux64 win32 win64 macosx]
-l --list_sdk_hosts list availables sdk host supported machines
--create_src_archive when set, copies sources of all deployed packages into build/tmp/deploy/sources
--deb_packages when set, use .deb package format instead of .ipk
god@dv6:~/poky/edison-src$ mkdir bb_ss_dir
We are building in external mode
Cloning into bare repository 'poky-mirror.git'...
remote: Counting objects: 290708, done.
remote: Compressing objects: 100% (71975/71975), done.
remote: Total 290708 (delta 214017), reused 289783 (delta 213092)
Receiving objects: 100% (290708/290708), 115.19 MiB | 763.00 KiB/s, done.
Resolving deltas: 100% (214017/214017), done.
Checking connectivity... done.
Cloning into bare repository 'meta-mingw-mirror.git'...
remote: Counting objects: 256, done.
remote: Compressing objects: 100% (191/191), done.
remote: Total 256 (delta 98), reused 203 (delta 45)
Receiving objects: 100% (256/256), 62.01 KiB | 0 bytes/s, done.
Resolving deltas: 100% (98/98), done.
Cloning into bare repository 'meta-darwin-mirror.git'...
remote: Counting objects: 577, done.
remote: Compressing objects: 100% (329/329), done.
remote: Total 577 (delta 244), reused 522 (delta 189)
Receiving objects: 100% (577/577), 6.90 MiB | 745.00 KiB/s, done.
Resolving deltas: 100% (244/244), done.
Cloning into bare repository 'meta-intel-iot-middleware-mirror.git'...
remote: Counting objects: 1008, done.
remote: Compressing objects: 100% (534/534), done.
remote: Total 1008 (delta 506), reused 880 (delta 380)
Receiving objects: 100% (1008/1008), 5.60 MiB | 685.00 KiB/s, done.
Resolving deltas: 100% (506/506), done.
Cloning Poky in the /home/god/poky/edison-src/out/linux64/poky directory
Cloning into 'poky'...
done.
Note: checking out 'yocto-1.7.2'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
git checkout -b new_branch_name
HEAD is now at 29812e6... busybox: unbreak tar of uncompressed files
Cloning Mingw layer to /home/god/poky/edison-src/out/linux64/poky/meta-mingw directory from local cache
Cloning into 'meta-mingw'...
done.
Cloning Darwin layer to /home/god/poky/edison-src/out/linux64/poky/meta-darwin directory from local cache
Cloning into 'meta-darwin'...
done.
Note: checking out '29b5ff31cee24e796f2eb2d2fd1269e3e92c831c'.
HEAD is now at 29b5ff3... gcc-runtime: Don't pollute global export namespace
Cloning meta-intel-iot-middleware layer to /home/god/poky/edison-src/out/linux64/poky/meta-intel-iot-middleware directory from local cache
Cloning into 'meta-intel-iot-middleware'...
done.
Note: checking out 'c6d681475e76107e6c04c5f7a06034dc9e772d1e'.
HEAD is now at c6d6814... upm: Update to 0.3.1
Cloning meta-arduino layer to /home/god/poky/edison-src directory from GitHub.com/01org/meta-arduino
Cloning into 'meta-arduino'...
remote: Counting objects: 72, done.
remote: Total 72 (delta 0), reused 0 (delta 0), pack-reused 72
Unpacking objects: 100% (72/72), done.
Already on '1.6.x'
Your branch is up-to-date with 'origin/1.6.x'.
Applying patch on poky
Initializing yocto build environment
Setting up yocto configuration file (in build/conf/local...
Sergio_A_Intel
I ran the test with the latest image and followed the similar steps. Notice in the log is a section that says:
** Success **
SDK will be generated for linux64 host
Now run these two commands to setup and build the flashable image:
cd /home/god/poky/edison-src/out/linux64
source poky/oe-init-build-env
I ran the commands for my settings and didn't receive any errors. Go to the linux64 folder instead of the edison-src folder and then run the source and bitbake commands.
Let me know your results.
Sergio
