I use edison arduino board. working good when upload program
but when don't working that use dc adapter,usb or battery.
I have uno.
Uno is working dc adapter, usb or battery but edison is not working.
I think power source is don't problem
do you know this problem?
Hi leejkjk,
I'm not following you. Could you please let me know if you have issues when powering the board with the DC power supply (or USB), or if you have issues with the Arduino sketch not starting automatically after the board is powered off/on?
-Diego
Board is can power on but don't start my program, DC or battery
edison only start my program when arduino sketch uploading
I konw arduino sketch upload my program, power off, other power on(dc or usb), automatically start my program
that right? but my edison, arduino sketch upload(do my program), power off, other power on(edison is on),but no automatically start my program
Hi leejkjk,
Thank you for the explanation.
The issue you are describing is a known issue with the latest Yocto image. The Arduino sketches don't start automatically after the board reboots.
There is a workaround for this posted by another user. You will have to re-flash the Edison with the 146 image version and copy some files from this image. Then, you have re-flash the Edison with the latest image again, and copy those files in this version. That should fix the issue. Please check the following thread where there is a step-by-step guide to perform this workaround: https://communities.intel.com/thread/77945 https://communities.intel.com/thread/77945
Diego
