Community
cancel
Showing results for
Search instead for
Did you mean:
hlim12
edison temperature sensor question..
hi, I use the grove temperature sensor.
https://software.intel.com/en-us/iot/hardware/sensors/pulse-sensor
Test code was used as a code over.
I tried a test,
"Temperature Sensor
74 degrees Celsius, or 165 degrees Fahrenheit
139 degrees Celsius, or 282 degrees Fahrenheit
147 degrees Celsius, or 296 degrees Fahrenheit
149 degrees Celsius, or 300 degrees Fahrenheit
151 degrees Celsius, or 303 degrees Fahrenheit
166 degrees Celsius, or 330 degrees Fahrenheit
154 degrees Celsius, or 309 degrees Fahrenheit
logout "
I'm not sure why the temperature is displayed for more than 100 degrees.
What's the problem?
Community Manager
Hello hwanhee,
I believe you posted the wrong link as the example found there is for a pulse sensor. Could you please verify the link and post the code you used?
-Peter.
hlim12
# include
# include
# include "pulsensor.h"
# include
using namespace upm;
int doWork = 0;
void
sig_handler(int signo)
printf("got signal\n");
if (signo == SIGINT) {
printf("exiting application\n");
doWork = 1;
void
handler (clbk_data data) {
printf ("callback data (%d)\n", data);
int
main(int argc, char **argv)
//! [Interesting]
Pulsensor *sensor = new Pulsensor(handler);
sensor->start_sampler();
while (!doWork) {
usleep (5);
sensor->stop_sampler();
//! [Interesting]
return 0;
this example using..
Community Manager
That is the code found in https://software.intel.com/en-us/iot/hardware/sensors/pulse-sensor. It is for a pulse sensor, it is not related to any temperature sensor. Could you please verify the code that you are using and post it or a link to it?
-Peter.
