Community
cancel
Showing results for
Search instead for
Did you mean:
mkim29
edison uart lib mraa send msg byte order.
hi. i have some question about mraa( uart).
i try send msg.(f1 10 02 51 01 f2 = ?Q?) this type is protocol (? msg ?)
it must be response same type (? somethig ?)
but order is incorrect. see that srcshot.
why is this? something i don't know. answer me.
Community Manager
Can you explain in more detail your issue? When you send a message are you not receiving the correct value, is it not in order, or you just want to know the protocol in which the messages are sent? How are you sending the data? Please provide a more detailed description of your testing scenario, code, commands used, base board used, etc.
Sergio
