Intel® Makers
9882 Discussions
error in detecting the port in ardiuno IDE
rchod
I AM WORKING ON THE INTEL GALILEO GEN 2. I AM FACING TROUBLE DURING THE SD CARD INSERTION.
WHEN EVER INSERT THE SD CARD. I CANNOT DETECT THE PORT IN ARDIUNO IDE. BUT IT WORKS IN NORMAL CONDITION WHEN EVER I REMOVE THE SD CARD,.
IN ORDER TO CONNECT IT TO WIFI I NEED SD CARD BOOT FILES. SO, HELP ME OUT TO SOLVE THIS ISSUE..
Community Manager
Hello Rajesh,
Thank you for your interest in our Intel products.
You may have flashed the operating system for the Galileo to the SD card wrongly (if you did install one in the first place), or your SD card may not be properly formatted. Download SD Card Formatter and set it to be fully formatted, then if you want to install the O/S for the Galileo board, extract the downloaded files via 7z directly onto the SD card and it should start working.
If you're still having issues, try a different SD card.
Octavian
Community Manager
Hello Rajesh,
Has your issue been resolved?
Octavian
