Intel® Makers
9872 Discussions
/etc/init.d/networking: No such file or directory problem.
MAham
I am trying to set up wifi connection in Galileo Gen2. I have installed iot-devkit-201510010757-mmcblkp0-galileo.direct on the board.
Recently I bought intel centrino 2230 ( http://www.amazon.in/ThinPc-Centrino-300mbps-Bluetooth-Antenna/dp/B01BBS1774/ref=sr_1_2?ie=UTF8&qid=... Amazon.in: Buy ThinPc Intel Centrino Mini PCI E Wi-Fi Card 300mbps Speed + Bluetooth 4.0 + Dual Antenna Online at Low Pr… ) and connected to the board. I confirmed its compatible firmware in /lib/firmwire/ (iwlwifi-2030-6.ucode).
I did the followings:
root@galileo:# lspci -k | grep -A 3 -i "network"
01:00.0 Network controller: Intel Corporation Centrino Wireless-N 2230 (rev c4)
Subsystem: Intel Corporation Centrino Wireless-N 2230 BGN
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
root@galileo:/etc/network# cat interfaces
cat: interfaces: No such file or directory
root@galileo:~# ifconfig
enp0s20f6 Link encap:Ethernet HWaddr 98:4F:EE:01:C6:FB
inet6 addr: fe80::9a4f:eeff:fe01:c6fb/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1147 errors:0 dropped:0 overruns:0 frame:0
TX packets:1910 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:181289 (177.0 KiB) TX bytes:697143 (680.8 KiB)
Interrupt:51
enp0s20f6:avahi Link encap:Ethernet HWaddr 98:4F:EE:01:C6:FB
inet addr:169.254.11.46 Bcast:169.254.255.255 Mask:255.255.0.0
Interrupt:51
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:81436 errors:0 dropped:0 overruns:0 frame:0
TX packets:81436 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:5868876 (5.5 MiB) TX bytes:5868876 (5.5 MiB)
wlp1s0 Link encap:Ethernet HWaddr 68:17:29:69:73:9B
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:156 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:42239 (41.2 KiB)
(wlan0 does not show up!)
root@galileo:~# cd /etc/network/
root@galileo:/etc/network# ls
if-down.d if-post-down.d if-pre-up.d
(if-up.d is also not present)
root@galileo:/etc/network# /etc/init.d/networking restart
-sh: /etc/init.d/networking: No such file or directory
Can you guys help on this?? I am really stuck in this.
FTinetti
Honored Contributor I
Hi syedahamad10,
Take a look at https://software.intel.com/en-us/blogs/2014/03/13/configuring-wifi-for-the-intel-galileo-board Configuring WiFi for the Intel Galileo Board | Intel® Software
Some other threads that may help:
HTH,
Fernando.
Community Manager
Hello syedahamad10,
In the eglibc image (which is the one you are using) wlan0 is not present, the wireless interface in shown as wlp1s0. Follow the next guide in order to enable Wi-Fi and configure it:
https://software.intel.com/en-us/node/519955
Let me know if it helps you.
Peter.
MAham
Thank you sir. It worked. Can you elaborate me for proxy setting?
Community Manager
Hi syedahamad10,
I haven't had the need to work behind a proxy before, but I think to configure it on your Galileo you'll need to enter the following export http=:. After that you should be able to have normal access. Similar to this thread: /thread/50712 https://communities.intel.com/thread/50712, take a look at the last post.
Pablo
