Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
eth0 device not found with LSB image
I am running LSB image, when i try to configure eth0 with ifconfig, i get
eth0: error fetching interface information: Device not found
i tried ifup eth0
eth0: ERROR while getting interface flags: No such device
ifconfig only shows settings for lo, nothing else.
Highlighted
looking at dmesg, it seems stmmaceth is not loaded at all, no sign of it or eth0 being loaded. could i have forgotten something when building the LSB image?
Highlighted
New Contributor II
Let's try some basic steps:
- Is one of the LEDs on the ethernet port on after powering the Galileo?
- Did you wait at least 30sec after turning off before a new start?
- Did you attached the ethernet cable to a network before you turned it on?
I use the LSB image too, and the only - regular - problem for me is, the Galileo does not recognize a connection, if I connect the cable *after* start up.
Highlighted
yes the orange light is on, after i plug in the ethernet cable a yellow light comes on.
yes waited 30 secs.
yes tried that too.
the eth0 port works perfectly fine without the LSB image, i compared the dmesg from both images, the difference is eth0 and its driver stmmac is not loaded for the LSB image at start up, i have attached the two outputs.
reading this documents on stmmac, https://www.kernel.org/doc/Documentation/networking/stmmac.txt https://www.kernel.org/doc/Documentation/networking/stmmac.txt, seems stmmac should be enabled in kernel configurations ( see under 1. ). seeing that it does not load at start up, maybe i should have enabled it before building the image? i used bsp version 0.9.
quick edit: seems my assumption about stmmac is wrong, it is loaded correctly into kernel, i dont understand why it isnt loading. excuse my random assumptions, i am learning this as on the go.
lsmod shows stmmac is used by 0.
Highlighted
New Contributor II
I'm not that linux/network guru and unfortunatly, your linux wizard is sick at home. And I also should mention, I'm still on a 0.7.5 based LSB image. And to make it worst: I broke my Wlan card yesterday. But let's try some other ideas:
I forgot one important question: How do you currently access the Galileo? Via Wlan?
The stmmac module on my Galileo is also used by 0 - although I'm currently connected to it via eth0.
Some other ideas to check:
- What shows lspci? I get this:
00:14.6 Ethernet controller: Intel Corporation Device 0937 (rev 10)
00:14.7 Ethernet controller: Intel Corporation Device 0937 (rev 10)
- Check your kernel configuration. You can do this on your host computer. In your ./yocto_build directory call:
bitbake virtual/kernel -c menuconfig
You get a GUI to configure the kernel. The following stuff should be enabled:
* Bus options (PCI etc) -> [*] PCI support
* Device Drivers -> Network device support -> [*] Ethernet driver support -> ...
On my kernel the following ethernet drivers are enabled:
[*] Cadence devices
[*] Intel devices ->
Intel(R) PRO/100 Gigabit Ethernet support
[*] STMicroelectronics devices ->
STMicroelectronics 10/100/1000 Ethernet driver
[*] STMMAC PCI bus support
[*] STMMAC DMA arbitration scheme
Highlighted
ntel(R) PRO/100 Gigabit Ethernet support was not selected... not sure how that happend. do i run bit bake again after config?
Edit: ran bitbake, much faster this time, almost began at the end. let see if it fixes the problem. thanks a mil for helping me out!
Highlighted
seems that isn't the problem, i will try to run 0.7.5 bsp and see if that helps. on the upside, i got the wifi working, able to connect through wifi.
Highlighted
I ran the board on 0.7.5 based LSB image, the ethernet works just fine now, i wonder if this was a bug on 0.9 ?
Highlighted
Solution to this problem is in post 6 of this thread
