Intel® Makers
9873 Discussions
ffmpeg command not found
JTurn12
New Contributor II
I am trying to snap a simple photo using a USB webcam. I am the full IOT yocto image and a galileo gen 2.
I have verified the dev/video0 file after plugging in the webcam.
Here is a log:
root@galileo:~# find /lib/modules/* -name 'uvc'
/lib/modules/3.8.7-yocto-standard/kernel/drivers/media/usb/uvc
root@galileo:~# lsmod | grep uvc
uvcvideo 71190 0
videobuf2_vmalloc 12875 1 uvcvideo
videobuf2_core 37680 1 uvcvideo
videodev 91716 2 uvcvideo,videobuf2_core
usbcore 144164 7 btusb,uvcvideo,usb_storage,ohci_hcd,ehci_hcd,ehc i_pci,usbhid
root@galileo:/home/ffmpg/ffmpeg# ./ffmpeg -version
ffmpeg version 2.8.5-static http://johnvansickle.com/ffmpeg/ http://johnvansickle.com/ffmpeg/ Copyright (c) 2000 -2016 the FFmpeg developers
built with gcc 4.9.3 (Debian 4.9.3-10)
configuration: --enable-gpl --enable-version3 --disable-shared --disable-debug - -enable-runtime-cpudetect --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libwebp --enable-libspeex --enable-libvorbis --enable-libvpx --enable-l ibfreetype --enable-fontconfig --enable-libxvid --enable-libopencore-amrnb --ena ble-libopencore-amrwb --enable-libtheora --enable-libvo-aacenc --enable-libvo-am rwbenc --enable-gray --enable-libopenjpeg --enable-libopus --enable-libass --ena ble-gnutls --enable-libvidstab --enable-libsoxr --enable-frei0r --enable-libfrib idi --disable-indev=sndio --disable-outdev=sndio --cc=gcc-4.9
libavutil 54. 31.100 / 54. 31.100
libavcodec 56. 60.100 / 56. 60.100
libavformat 56. 40.101 / 56. 40.101
libavdevice 56. 4.100 / 56. 4.100
libavfilter 5. 40.101 / 5. 40.101
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 2.101 / 1. 2.101
libpostproc 53. 3.100 / 53. 3.100
root@galileo:/home/ffmpg/ffmpeg# ffmpeg -f fbdev -vframes 1 -r 1 -i /dev/fb0 screenshot.jpeg
-sh: ffmpeg: command not found
Any tips for me? Perhaps I'm just goofing the command up. I did change the folder name to a simple "ffmpeg", but that should be fine right?
asss
Valued Contributor II
have you tried to do like this?
root@galileo:/home/ffmpg/ffmpeg# ./ffmpeg -f fbdev -vframes 1 -r 1 -i /dev/fb0 screenshot.jpeg
BR,
xbolshe
JTurn12
New Contributor II
hi thanks for the suggestion,
here is the result:
ffmpeg version 2.8.5-static http://johnvansickle.com/ffmpeg/ http://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2016 the FFmpeg developers
configuration: --enable-gpl --enable-version3 --disable-shared --disable-debug --enable-runtime-cpudetect --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libwebp --enable-libspeex --enable-libvorbis --enable-libvpx --enable-libfreetype --enable-fontconfig --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-gray --enable-libopenjpeg --enable-libopus --enable-libass --enable-gnutls --enable-libvidstab --enable-libsoxr --enable-frei0r --enable-libfribidi --disable-indev=sndio --disable-outdev=sndio --cc=gcc-4.9
Option vframes (set the number of video frames to output) cannot be applied to input file /dev/fb0 -- you are trying to apply an input option to an output file or vice versa. Move this option before the file it belongs to.
Error parsing options for input file /dev/fb0.
Error opening input files: Invalid argument
asss
May be need to use /dev/video0 instead of /dev/fb0 ?
BR,
xbolshe
JTurn12
New Contributor II
and here is the result of that..
Option vframes (set the number of video frames to output) cannot be applied to input file /dev/video0 -- you are trying to apply an input option to an output file or vice versa. Move this option before the file it belongs to.
Error parsing options for input file /dev/video0.
hmm
JTurn12
New Contributor II
I could not get this to work, but I did manage to get a photo using Video4Linux...
thanks to rgb
  1. Get the file
git clone https://github.com/twam/v4l2grab.git https://github.com/twam/v4l2grab.git
2. CD into into directory
cd v4l2grab
3. Generate the autotools files
./autogen.sh
4. Run configure
./configure
5. Run make
make
6. Run make install
sudo make instal
7. make sure you have /dev/video, if not modprobe uvcvideo
