Intel® Makers
9882 Discussions
ffmpeg video streaming error
Community Manager
hello everyone,
I'm using ffmpeg to stream video. But the problem is when I run the following command to stream video, it gives the error:
root@edison:- ffmpeg -s 320x240 -f video4linux2 -i /dev/video0 -f mpeg1video -b 800k -r 30 http://192.168.1.9:8080 http://192.168.1.9:8080
Connection to tcp://192.168.1.9:8080 failed: Connection refused
http://192.168.1.9:8080: http://192.168.1.9:8080: Connection refused
How should I solve this ?
Carlos_M_Intel
Hi Falak,
How are you installing FFMPEG?
Could you attach all the log you are getting after your command?
Also, are you editing the ffserver.conf? https://trac.ffmpeg.org/wiki/ffserver ffserver - FFMPEG
Charlie
Community Manager
Hi CMata_Intel,
I installed ffmpeg from the instructions given in https://github.com/drejkim/edi-cam edi-cam git repository.
I also installed ffmpeg on my ubuntu 14.04 machine. And I built that from https://www.ffmpeg.org/download.html source. but still the same error is appearing.
do_ffmpeg.sh file contains following command:
# !/bin/sh
/home/root/ffmpeg/ ffmpeg -s 320x240 -f video4linux2 -i /dev/video0 -f mpeg1video -b 800k -r 30 http://192.168.1.9:8080 http://192.168.1.9:8080
(where 192.168.1.9 is my edison ip & /home/root/ffmpeg is the folder where my ffmpeg is installed)
edison output log:-
root@edison:~/ffmpeg# ./do_ffmpeg.sh
ffmpeg version 2.8.1-static http://johnvansickle.com/ffmpeg/ http://johnvansickle.com/ffmpeg/ Copyright (c) 2000-2015 the FFmpeg developers
built with gcc 4.9.3 (Debian 4.9.3-4)
configuration: --enable-gpl --enable-version3 --disable-shared --disable-debug --enable-runtime-cpudetect --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libwebp --enable-libspeex --enable-libvorbis --enable-libvpx --enable-libfreetype --enable-fontconfig --enable-libxvid --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-gray --enable-libopenjpeg --enable-libopus --enable-libass --enable-gnutls --enable-libvidstab --enable-libsoxr --enable-frei0r --enable-libfribidi --cc=gcc-4.9
libavutil 54. 31.100 / 54. 31.100
libavcodec 56. 60.100 / 56. 60.100
libavformat 56. 40.101 / 56. 40.101
libavdevice 56. 4.100 / 56. 4.100
libavfilter 5. 40.101 / 5. 40.101
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 2.101 / 1. 2.101
libpostproc 53. 3.100 / 53. 3.100
Input # 0, video4linux2,v4l2, from '/dev/video0':
Duration: N/A, start: 1041.689040, bitrate: 36864 kb/s
Stream # 0:0: Video: rawvideo (YUY2 / 0x32595559), yuyv422, 320x240, 36864 kb/s, 30 fps, 30 tbr, 1000k tbn, 1000k tbc
Please use -b:a or -b:v, -b is ambiguous
[tcp @ 0xba67b60] Connection to tcp://192.168.1.10:8080 failed: Connection refused
http://192.168.1.10:8080: http://192.168.1.10:8080: Connection refused
Ubuntu output log:-
(where 192.168.1.33 is my ubuntu machine ip)
root@Linux:~/Desktop$ ffmpeg -s 320x240 -f video4linux2 -i /dev/video0 -f mpeg1video -b 800k -r 30 http://192.168.1.33:8080 http://192.168.1.33:8080
ffmpeg version 2.8.1 Copyright (c) 2000-2015 the FFmpeg developers
built with gcc 4.8 (Ubuntu 4.8.4-2ubuntu1~14.04)
configuration:
Duration: N/A, start: 2057.572086, bitrate: 36864 kb/s
[tcp @ 0xa3ef820] Connection to tcp://192.168.1.33:8080 failed: Connection refused
http://192.168.1.33:8080: http://192.168.1.33:8080: Connection refused
how do I solve this error ?
Carlos_M_Intel
Hi Falak,
The file bin/do_ffmpeg.sh is intended to be used alongside with the server.js code. You are getting that error due to that.
If you don't want to use the server.js file you need to start using ffserver.
Charlie
