Intel® Makers
9877 Discussions
fichier repo > xdk > git clone problem
dvian
Hello, I just received my intel is edison arduino I install the repo file on my card but then I can not dévelloper project's price starting from XDK so I can not make GIT CLONE aurrait there are there a solution ??
Sergio_A_Intel
I'm afraid I don't understand what you're asking. What do you mean with
"I can not dévelloper project's price starting from XDK so I can not make GIT CLONE aurrait"
Can you please be more specific?
Sergio
dvian
hey sorry I'm French translation is not good When I'm in the root serial connection, I can not make GIT CLONE so I install:
echo src / gz all http://repo.opkg.net/edison/repo/all http://repo.opkg.net/edison/repo/all
echo src / gz edison http://repo.opkg.net/edison/repo/edison http://repo.opkg.net/edison/repo/edison
echo src / gz core2-32 http://repo.opkg.net/edison/repo/core2-32 http://repo.opkg.net/edison/repo/core2-32
When it is installed and GIT CLONE walking, but on the XDK intel I can not log in anymore, and the serial Port I only have the serial port and the edison intel as start the disk does not open and I can only communicate by linux
So my concern is that once I put the echo I have more communication with Arduino and xdk intel. it's normal? So to be able develloper I have to reboot to do image ... how to do?
french :
mon soucis est que je ne peux pas installer un git clone.
pour l'installer j'installe :
est du coup git clone marche mais pas le reste, c'est a dire que ensuite l'ordinateur ne détecte plus Edison sauf avec le port com série...
que faire??
dvian
Hi, I see many intel edison project with GitHub file. But how do faires are run on intel edison ?? I look and I find you first install:
echo src/gz all http://repo.opkg.net/edison/repo/all http://repo.opkg.net/edison/repo/all > /etc/opkg/base-feeds.conf
echo src/gz edison http://repo.opkg.net/edison/repo/allsrc/gz http://repo.opkg.net/edison/repo/allsrc/gz >> /etc/opkg/base-feeds.conf
echo src/gz core2-32 http://repo.opkg.net/edison/repo/allsrc/gz http://repo.opkg.net/edison/repo/allsrc/gz >> /etc/opkg/base-feeds.conf
echo src all http://iotdk.intel.com/repos/1.1/iotdk/all http://iotdk.intel.com/repos/1.1/iotdk/all >> /etc/opkg/base-feeds.conf
echo src x86 http://iotdk.intel.com/repos/1.1/iotdk/x86 http://iotdk.intel.com/repos/1.1/iotdk/x86 >> /etc/opkg/base-feeds.conf
echo src i586 http://iotdk.intel.com/repos/1.1/iotdk/i586 http://iotdk.intel.com/repos/1.1/iotdk/i586 >> /etc/opkg/base-feeds.conf
and when it's over everything works
