Community
cancel
Showing results for
Search instead for
Did you mean:
PMuld2
New Contributor II
flashall script gives no response
I am trying to run the flashall script to upgrade the Intel Edison firmware (via MacOS).
I see this:
pm:edison-image-ww05-15 pmu$ ./flashall.sh
Using U-Boot target: edison-blankcdc
Now waiting for dfu device 8087:0a99
Please plug and reboot the board
dfu-util: Device has DFU interface, but has no DFU functional descriptor
Flashing IFWI
Flashing U-Boot
Flashing U-Boot Environment
Flashing U-Boot Environment Backup
Rebooting to apply partition changes
But then it seems that the script hangs.
Any options to debug this?
Thanks!
PMuld2
New Contributor II
Especially, it might be nice to learn more about the command:
# reboot ota
and when in bootloader mode:
microkernel built 23:15:13 Apr 24 2014
******* PSH loader *******
PCM page cache size = 192 KB
Cache Constraint = 0 Pages
Arming IPC driver ..
Adding page store pool ..
PagestoreAddr(IMR Start Address) = 0x04899000
pageStoreSize(IMR Size) = 0x00080000
*** Ready to receive application ***
U-Boot 2014.04 (Aug 20 2014 - 16:08:32)
Watchdog enabled
DRAM: 980.6 MiB
MMC: tangier_sdhci: 0
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
boot >
how to do some basic checks if any update has been applied already?
Or possibly control to upgrade from here?
PMuld2
New Contributor II
Possibly, there is an approach to do the upgrade via:
boot > run do_ota
reading ota_update.scr
** Unable to read file ota_update.scr **
Saving Environment to MMC...
Writing to MMC(0)... done
resetting ...
PMuld2
New Contributor II
also with the phone flash tool lite, I get no response:
12/27/15 22:16:18.741 INFO : [Port 1/3] osimage -- /Users/pmu/Downloads/edison-iotdk-image-280915/u-boot-edison.img
12/27/15 22:16:18.741 INFO : [Port 1/3] gpflags -- 0x80000007
12/27/15 22:16:18.741 INFO : [Port 1/3] softfuse --
12/27/15 22:16:18.748 INFO : [Port 1/3] XFSTK-STATUS--Detecting Intel Device - Attempt # 0
12/27/15 22:16:19.749 INFO : [Port 1/3] XFSTK-STATUS--Detecting Intel Device - Attempt # 1
12/27/15 22:16:20.750 INFO : [Port 1/3] XFSTK-STATUS--Detecting Intel Device - Attempt # 2
12/27/15 22:16:21.751 INFO : [Port 1/3] XFSTK-STATUS--Detecting Intel Device - Attempt # 3
12/27/15 22:16:22.753 INFO : [Port 1/3] XFSTK-STATUS--Detecting Intel Device - Attempt # 4
12/27/15 22:16:23.754 INFO : [Port 1/3] XFSTK-STATUS--Detecting Intel Device - Attempt # 5
12/27/15 22:16:24.756 INFO : [Port 1/3] XFSTK-STATUS--Detecting Intel Device - Attempt # 6
12/27/15 22:16:25.758 INFO : [Port 1/3] XFSTK-STATUS--Detecting Intel Device - Attempt # 7
12/27/15 22:16:26.760 INFO : [Port 1/3] XFSTK-STATUS--Detecting Intel Device - Attempt # 8
12/27/15 22:16:27.761 INFO : [Port 1/3] XFSTK-STATUS--Detecting Intel Device - Attempt # 9
12/27/15 22:16:28.763 INFO : [Port 1/3] XFSTK-STATUS--Detecting Intel Device - Attempt # 10
12/27/15 22:16:29.764 INFO : [Port 1/3] XFSTK-STATUS--Detecting Intel Device - Attempt # 11
12/27/15 22:16:30.766 INFO : [Port 1/3] XFSTK-STATUS--Detecting Intel Device - Attempt # 12
PMuld2
New Contributor II
Now, after booting and rebooting the Laptop, flashall was not yet running successfully.
But I tried then the flash lite tool again, and now it seemed to have worked:
"/Users/pmu/Downloads/edison_fw/edison-image-edison.hddimg" "-t" "4096" "-d" "8087:0a99"` succeed
12/27/15 22:31:56.716 INFO : [Port 1/3] Running `"/Applications/Phone Flash Tool Lite.app/Contents/MacOS/dfu-util" "--alt" "rootfs" "-D" "/Users/pmu/Downloads/edison_fw/edison-image-edison.ext4" "-t" "4096" "-R" "-d" "8087:0a99"` command
12/27/15 22:35:48.568 INFO : [Port 1/3] Command `"/Applications/Phone Flash Tool Lite.app/Contents/MacOS/dfu-util" "--alt" "rootfs" "-D" "/Users/pmu/Downloads/edison_fw/edison-image-edison.ext4" "-t" "4096" "-R" "-d" "8087:0a99"` succeed
12/27/15 22:35:48.568 INFO : [Port 1/3] Running `Notify` command
12/27/15 22:35:48.634 INFO : Displaying notification during 60000 ms
12/27/15 22:35:48.634 INFO : [Port 1/3] Command `Notify` succeed
12/27/15 22:35:48.635 INFO : [Port 1/3] Flash success (duration=00:04:43.869)
And on the Edison serial debug port:
-Boot 2014.04 (Jun 19 2015 - 12:05:55)
Watchdog enabled
DRAM: 980.6 MiB
In: serial
Out: serial
Err: serial
Writing to redundant MMC(0)... done
Target:blank
Partitioning using GPT
Writing GPT: success!
Flashing already done...
GADGET DRIVER: usb_dnl_dfu
DFU complete CRC32: 0xb98db2f8
DOWNLOAD ... OK
Ctrl+C to exit ...
Sergio_A_Intel
I'm glad you managed to flash your board. I noticed you were trying to flash image ww05-15. There is a newer version from ww25.5-15 that can be found here http://downloadmirror.intel.com/25028/eng/edison-image-ww25.5-15.zip http://downloadmirror.intel.com/25028/eng/edison-image-ww25.5-15.zip . About the reboot OTA method, this method is no longer used. You'll get an error if you try to flash the latest image using this method. You can see more information here
Sergio
