Intel® Makers
9872 Discussions
flashing Edison - not detected on Mac
KKotc
Hey all,
I'm new to Edison- but have worked with Pi and Arduino enough to know something is wrong.
Here's the deal:
I have an Intel Edison board on a breakout board (specifically- this one: https://www.amazon.com/gp/product/B00PTVSVI8/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 Amazon.com: Intel Edison Breakout Board Kit [Dual Core Intel Atom IA-32 500MHz, 4GB eMMC Storage, Bluetooth 4.0, WiFi En… )
I've tried manually flashing the board on 2 different macs. Initially my comp mounted the board but the flash seems to have failed.Here is as far as it got:
>> ./flashall.sh
Using U-Boot target: edison-blankcdc
Now waiting for dfu device 8087:0a99
Please plug and reboot the board
Timed out while waiting for dfu device 8087:0a99
Now the board will not mount nor can I get past the above.
Help!
Thank you,
K
KKotc
Just tried with the Intel Board Config Tool. Screenshot below
Community Manager
Hello kenneth456,
Thanks for reaching out!
Could you please let us know which guide you were using to flash your board? And if you haven't tried the one found in https://communities.intel.com/docs/DOC-25154 https://communities.intel.com/docs/DOC-25154, I suggest you to do so.
Also, do you have access to PC? I've noticed, that sometimes the issue is on the PC and not the board. For example, I can't flash my Edison on my PC, it just fails, but if I use a different PC, the board will flash with no problems. So, you might want to try using a different PC to see if you get different results.
I hope this information helps you,
Pedro M.
KKotc
Yes, those are the directions I followed.
I tried on 3 Macs. I do not have access to Win or Linux.
Help!
KMill10
Valued Contributor II
Here is some info to see if your Edison is connecting via USB or not...
On your Mac, please try the following:
Open the "Terminal" app.
Unplug your edison completely.
In the terminal app enter the following command:
ioreg -p IOUSB
Now plug in your edison and do the same command again:
ioreg -p IOUSB
Now copy and paste the results from the terminal window into a reply here.
KKotc
Thank you for the reply. Below are my results:
//with powered usb hub
Script started on Wed Apr 19 08:29:02 2017
[?1034h>> ioreg -p IOUSB
+-o Root
+-o Root Hub Simulation Simulation@14000000
| +-o iBridge@14200000
+-o Root Hub Simulation Simulation@00000000
+-o Root Hub Simulation Simulation@01000000
>> ioreg -p IOUSB
+-o Root
| +-o IOUSBHostDevice@14100000
| +-o FT232R USB UART@14110000
>> ex [K [Kexit
exit
Script done on Wed Apr 19 08:30:17 2017
//without usb hub
Script started on Wed Apr 19 08:31:25 2017
+-o Root
>> ioreg -p IOUSB
+-o Root
>> exit
exit
Script done on Wed Apr 19 08:32:20 2017
KMill10
Looks to me like your Edison is there, but is connected with the RS232 Port, not the flash port.
Do you have BOTH USB Cables attached to the mac or just one?
For flashall.sh to work you only need to connect the breakout board using J16. Plug and Unplug this port when asked by Flashall.
If you have both USB cables connected, then only one is being detected. This could mean there is a problem with the Edison, the Breakout board, or both - or the USB cables.
KKotc
On the try WITH usb hub, I had both plugged in.
On try WITHOUT hub, only J16 was plugged in.
I have tried 4 different usb cables from 3 manufacturers, each works for data with other drives.
Just tried again (without usb hub) and below is where it hangs. I wait 5 min (when it says 2) then reboot with breakout board button:
>> ./flashall.sh
dfu-util: Device has DFU interface, but has no DFU functional descriptor
Flashing IFWI
Flashing U-Boot
Flashing U-Boot Environment
Flashing U-Boot Environment Backup
Rebooting to apply partition changes
Flashing boot partition (kernel)
Flashing rootfs, (it can take up to 10 minutes... Please be patient)
Rebooting
U-boot & Kernel System Flash Success...
Your board needs to reboot to complete the flashing procedure, please do not unplug it for 2 minutes.
What next?
Ken
Community Manager
Hello kenneth456,
If you still have issues with Edison, I'd suggest you to submit an email to the following form https://customercare.intel.com/?lang=en-US. We might be able to provide further assistance there.
Pedro M.
