Intel® Makers
9873 Discussions
galileo gen2 and ttys1
CCris5
Hello all, i need to use 2 serial ports to receive serial data from gps, i have 2 x DB9 connectors, and i need this 2, no option, USB is busy with a USB CAN device and i need to use this.
I'm booting with yocto linux, ttyS0 (PIN 0,1) is working fine and receiving, but ttyS1 (PIN 2,3) is attached to console and don't receive
root@galileo:/# dmesg | grep console
[ 0.000000] Early serial console at MMIO32 0x8010f000 (options '115200n8')
[ 0.000000] bootconsole [uart0] enabled'
[ 0.000000] Kernel command line: root=/dev/mmcblk0p2 rootwait console=ttyS1,115200n8 earlycon=uart8250,mmio32,0x8010f000,115200n8 reboot=efi,warm apic=debug rw LABEL=boot debugshell=5 efi_main=0x000000016c202a74 jmp_code32=0x00000001ff87a1ea
[ 0.899149] console [ttyS1] enabled, bootconsole disabled
I'm using console with ethernet, i don't need serial console, i need to receive ttyS1 data in pins 2,3
Can anybody help me on how to disable or switch this? i have all my system running and i don't like to recompile kernel.
i can't see grub init file in /boot and i need to change the kernel command line; i think.
Can anybody help me?
Thank you,
Cristian
Sergio_A_Intel
In Galileo, the serial ports are:
/dev/ttyS0 is the first Quark UART (UART0) and it's the Digital 0 and 1 pins
/dev/ttyS1 is the second Quark UART (UART1) and it's the audio jack one.
Your objective is to have ttyS1 in pins 2 and 3 instead of the audio jack right? I'd suggest you to take a look at /etc/systemd/system/getty.target.wants# . Here you'll find the services that manage the serial ports:
getty@tty1.service
serial-getty@ttyS1.service
Also, take a look at this thread it has a very similar question and a suggestion that worked for the user. Hopefully you can find this helpful.
Sergio
Sergio_A_Intel
getty@tty1.service
Sergio
CCris5
Hello, Sergio, and thank you for your answer.
If i disable the console service, ttyS1 will work in Pins 3,4 by default, like ttyS0 in Pins 1,2 ?
Cristian
Sergio_A_Intel
Have you made any progress trying to receive ttyS1 data in pins 2 and 3? I've never tried to do something like this but to do it you'd probably have to make another service that specifies that the data that is sent/received from the audio jack will now transferred to pins 2 and 3. This service will look much like the services in /etc/systemd/system/getty.target.wants# .
Try with this approach and let me know your results.
Sergio
