Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
hi,everyone
how do i install software package into linux on the galileo board?
do we have official package site about opkg?
thanks
Accepted Solutions
Highlighted
Valued Contributor I
Hi Neo-V
The answer depends on the operating system you are using.
If you are using the standard Linux from /docs/DOC-22226 https://communities.intel.com/docs/DOC-22226, there isn't an official repository.
There is an unofficial one run by AlexT and you can set up your system to access it, but it is easier to just go ahead and install his image that includes development tools and is setup to access his repository. Go to http://alextgalileo.altervista.org/blog/updated-galileo-devtools-image/ http://alextgalileo.altervista.org/blog/updated-galileo-devtools-image/
If you are using XDK IoT it has a repository and you can use opkg. see
If you are using one of the Debian or other versions of Linux, you should be able to use apt-get to install applications, but there is no official Intel repository.
Hope this helps
rgb
Highlighted
Hi Neo-V
Hope this helps
rgb
Highlighted
I'm using linux image compiled by bitbake,I just want to install nfs-common through opkg .
but i 'cant find one in the repo .
Highlighted
Hi Neo-v
Since you rolled your own, I don't know if this will work, but you can look at what AlexT's instructions for adding his repo at http://alextgalileo.altervista.org/package-repo-configuration-instructions.html Galileo Package Repo Configuration Instructions and see if it matches what you built. Otherwise I would guess you need to download the source code and compile it, assuming you included the development tools.
Sorry can't be more helpful, but i just use the standard versions.
rgb
