Intel® Makers
9881 Discussions
/home creation in post_install.sh (permissions/attributes)
MLeis4
I've found the mirroring/creating of /home on edison/yocto to be unusual to say the least.
When changing permissions in /home in the flash image (and creating account in early first boot), I "noticed" the permissions didn't change -- and the dates were all "current"
Digging into this, I noticed in post_install.sh theres:
if [ "$ota_done" != "1" ];
then
# backup initial /home/root directory
mkdir /tmp/oldhome
cp -R /home/* /tmp/oldhome/
fi_assert $? "Backup home/root contents of rootfs"
# format partition home to ext4
mkfs.ext4 -m0 /dev/disk/by-partlabel/home
fi_assert $? "Formatting home partition"
# mount home partition
mount_home
# copy back contents to /home and cleanup
cp -R /tmp/oldhome/* /home/
rm -rf /tmp/oldhome
fi_assert $? "Restore home/root contents on new /home partition"
Instead of cp -R it should use cp -a (perserve attributes/permissions recursively)
In addition, it makes an extra copy -- why not mount home someplace else, copy (actually should it move?) and then remount home.
marty
Community Manager
Hello martyl,
Thank you for sharing that information with the community. I personally have never had any issues with post_build.sh, nevertheless, this information might be of much help for other users.
We really appreciate you help.
-Peter.
MLeis4
This was a problem in correct ownship/permissions in /home.
This seems to fix the problem:
diff --git a/meta-intel-edison/meta-intel-edison-distro/recipes-core/post-install/files/post-install.sh b/meta-intel-edison/meta-intel-edison-distro/recipes-core/post-install/files/post-install.sh
index 0d24d06..96a3ffe 100644
--- a/meta-intel-edison/meta-intel-edison-distro/recipes-core/post-install/files/post-install.sh
+++ b/meta-intel-edison/meta-intel-edison-distro/recipes-core/post-install/files/post-install.sh
@@ -158,7 +158,7 @@ if [ "$ota_done" != "1" ];
then
mkdir /tmp/oldhome
- cp -R /home/* /tmp/oldhome/
+ cp -a /home/* /tmp/oldhome/
@@ -169,7 +169,7 @@ then
mount_home
- cp -R /tmp/oldhome/* /home/
+ cp -a /tmp/oldhome/* /home/
rm -rf /tmp/oldhome
